Is this true with the R as it is with the standard GT350? The R is supposed to have a more aggressive alignment from the factory, so I'm curious what Ford is doing differently if there's no adjustment.You have zero adjustment with the stock setup. It is about -1.0 to -1.1 factory. You can get different lower strut bolt that are not splined and hog out/elongate the aluminum strut Hub holes to get up to about -1.75 deg but then it also puts the tire closure to the damper body. So I went to camber plates to easily get up to -2.2 deg.
Could just be a byproduct of slightly shorter springs?Is this true with the R as it is with the standard GT350? The R is supposed to have a more aggressive alignment from the factory, so I'm curious what Ford is doing differently if there's no adjustment.
Yes. Mine is with an R. I am not aware of any way there could be differences between an R and non-R regarding camber as all parts affecting this spec are identical. The spring heights could affect the resting camber but from my measurements from mine to others non-R, the resting heights are not that different when you take into account the difference in tire diameter. Yes, the spring is shorter, but the spring rate is about 50 lbs/in different so the resting spring length is pretty close.Is this true with the R as it is with the standard GT350? The R is supposed to have a more aggressive alignment from the factory, so I'm curious what Ford is doing differently if there's no adjustment.
