WItoTX
It has been a while since I posted. Since then I have gotten the AAD arms installed, AAD camber links installed, and vertical links installed. The alignment process turned out to be an absolute monster, mostly due to my inability to understand geometry, which often led me to installing the wrong tab into either the toe link or camber arm. Which then led to wonky alignment specs. Here are the three new components installed.
The install was relatively easy. However, these AAD arms should be aligned in a specific order. First get camber dialed in, then mess with toe. It took me nearly two weeks to learn this one, despite speaking with the AAD guys several times, and them specifically telling me to do this.
AAD were fantastic. They sent basically another complete set of toe tabs to get the car dialed in when mine was outside of the typical tabs they send. The final result was slightly over -2 degrees camber both sides, and – 2mm driver side, -1mm toe in passenger side. I can go down one to link and I think I will be matching, but after two weeks of all my tiny amount of free time going towards the alignment, I am done. I will probably take it in or buy an alignment rack before I do it from home again!
I also had some free time to swap out the old catch can. The can I had in there was from a company who made quality cans for Hellcats. I assumed that same level would apply to the GT350, but it actually rested on the studs coming out of the valve cover and intake and felt cheap. This new one, also from AAD, replaces the radiator mount, and then sets between the radiator and the windshield wash filler.
The finish is nice, and feels much sturdier than the old can. The only downfall, it isn’t exactly easy to get to.
I also got the rear seat cleaned up. I kept all the wires in place as I am going to wire an amp back in at some point so I can listen to music again. Until then, its just the sound of the FPC.
I am not particularly happy with the fit and finish, but it’s better than looking at wires and the trunk. I will eventually swap it out with the Ford Performance delete once I can get my hands on one.
With the suspension swapped out, and all the other weight reduction I have done, I am down 173 lbs. I am ready for the next autocross to see how the camber does in the rear, or if I need to find more rear grip somewhere else.
I am caught up for now. I have hubs on the list to do, but they are not pressing as I am going to hold off on rims until later this year. Apex has something in the 20 lb range, but I would guess they, or someone else, has something a little lighter later this year.
