GT350 axles!
lemers
Globetrotter
Carlisle, PA
2016 GT350
Really want to see how this works out
stanglife
Jeff
1993 Coyote Coupe
Now that you are posting pics - how about pics of installed forgelines?
Hack
Minneapolis
Mustang, Challenger
It was posted yesterday per Ford Performance the 4.09 gear will not be offered.
"Ford Performance has verified the 4.09 gears have been axed. They would fit, but problems with several calibrations that would be needed (not speedo)"
Somewhat makes sense to me. The 4.09 just isn't a big enough change to be worth it, I don't think.
I've always heard that manufactures use different diameter half shafts to prevent wheel hop. I don't remember the exact theory behind it but perhaps someone else will chime in.
Wheel hop is associated with the "springiness" in the system. If you have different stiffness components on each side the wheels won't hop together. I'm not sure whether the design would really eliminate wheel hop completely. I think it would merely reduce the damaging effects on the drivetrain by preventing both wheels from hopping together.
Voodooo
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Lol. You'll have to wait now. They are all off the car as is the suspension.
Voodooo
Voodooo
SE Michigan
Scott
I never heard of such a thing. If this is what they said they are wrong because I had wheel hop. Not only from a launch but also from power shifting. The control arms and cradle have to much movement from the rubber bushings.
I know I seen the ford performance GT350 specific axles somewhere, but now I can't find the damn part numbers. I remember them costing list around $1700 for the pair. All I can find are GT350 axles to be used in the GT's. In the ford performance catalog they said you couldn't use the G-Froce (ford performance) axles in the gt350. Why not? The splines are the same. Why is it ok to use stock gt350 axles in the GT but not aftermarket GT axles in the gt350? Makes no sense.
partyelmarty
What's it trap?
San Antonio, TX
www.flickr.com
2015 Mustang GT, Magnetic Metallic
That's a great looking jig/stand! I'll definitely be making one when I'm back in the states, and will probably use the same mounting points as you did. Thanks for taking the pictures.
dron_jones
Fell into a pot hole in Michigan and can't get bac
Me crazy, and I can't help myself
It's true, the difference in sizes creates a difference in torsional rigidity between the two sides, this differential is intended to reduce wheel hop. Key word is reduce, it's possible to still have wheel hop caused by exactly the things you are replacing, the point would be that it would have been even worse before. The part that surprises me is that each side had a different splined diameter. Usually they keep that constant.
Good luck with the install. Looks great.
Voodooo
Voodooo
SE Michigan
Scott
The spline diameters are the same on both ends.
dron_jones
Ah ok. This is not uncommon, often though it's seen on aftermarket upgrades. Ours our factory which is cool. The way you can think about the wheel hop is if the axels get loaded up like torsional springs when you release the power (or spring) they will both jump off the ground at the same rate causing both wheels to leave the ground at the same time, if you have different spring rates (or rigidities) on each side the wheels will leave the ground at different rates thus increasing probability of having wheel contact at a given time
Voodooo
Voodooo
SE Michigan
Scott
I understand how wheel hop works lol. I've drag raced for 25 years. Just never seen two different diameter axles used together. But I see your point. It's like a torque stick. (spring steel)
dron_jones
Wasn't meant to be patronizing, probably others reading this thread that aren't as familiar so hopefully was helpful for them.
Good luck with the rest of the install. Will be interested to hear feedback after its completed. While I'm sure the wheel hop will dramatically improved I'm curious how the car will be in a daily driving situation, if it will still be comfortable or if it will be a lot more bone jarring.
Voodooo
Voodooo
SE Michigan
Scott
I didn't take what you said as patronizing :cheers: I know what you were explaining and agree with you.
I'll keep this thread going as I progress.
Bossing
attacks tracks
So. FL
Just can't get enuff!
Hey [MENTION=19530]Voodooo[/MENTION] So are you really Richard Dean Anderson.... aka the ingenious MacGyver in disguise? :D
Nice work/tinkering & mods btw.... :thumbsup:
Voodooo
Voodooo
SE Michigan
Scott
Lol. Yep and I made it with my pocket knife and a gum wrapper.
