True that, I was thinking tune next and then headers down the road.They bolt onto the block like headers, why not just get long tubes if going through all of the install labor already?
This is impossible. The drivers side cat is welded into the header.
Might as well just buy longtubes at that point I would think?They use a stock header with the cat cut off and a straight pipe welded back on. Either new from Ford or from people pulling their stock headers.
Exactly my recommendation to OP. If you're going through the same labor do the longtubes.Might as well just buy longtubes at that point I would think?
I guess replacing the header is bolt on, but a complete waste if you're replacing with stock. Calling it a "cat delete pipe" instead of a header is a little wrong.They use a stock header with the cat cut off and a straight pipe welded back on. Either new from Ford or from people pulling their stock headers.
You should not damage the cat in any way by cutting it. You can even add a flange to the cut side of the catalytic and made it a bolt-on piece, if you ever have to go backwards.Any damage to the cat after the cut?
