Groaning Noise
Cobrakit
Southern Maryland
Ken
2019 Mustang GT PREMIUM PP1
19 GT premium, a10, pp1, active exhaust. I have a random groaning noise when driving car and appears to be independent of driving modes. It sounds like its from front and maybe an actuator moving like noise. Any thoughts on origin of noise?
Cobrakit
Cobrakit
Southern Maryland
Ken
Nobody has ever heard a random groaning/moaning noise? Hate to take to dealership and waist my time, even though car is still under warranty. Car seems to run fine, just a random noise.
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
Sure, I hear random noises all the time. Can you tell me what they are from?
What you are asking is almost impossible to answer.
Cobrakit
Cobrakit
Southern Maryland
Ken
I don't know what the noise is from, that is why i was posting. To more clearly define, it happens everytime i drive and sounds like an electric motor/actuator running. The noise is short in duration and does not have any repetitive pattern. Its not a road noise, suspenion, brake, internal engine or interior noise. Not sure what the direct injection pump sounds like or if it would be random. Does not seem to make noise until i drive, but i will pop hood and check with engine idling. I don't think its coming from back of car, so does active exhaust actuator make noise? Would think that an in tank fuel pump noise would be constant, not random. Still thinking its coming from front of car.
Cobrakit
Cobrakit
Southern Maryland
Ken
Thanks, did not know i had those. This might mean why i have only heard when driving. So then question would be how do you determine if system is acting normal or starting to fail.
Yes to PP1.
Cobrakit
Cobrakit
Southern Maryland
Ken
Just confirmed, no shutters! When i say random, i mean that it happens everytime i drive, but noise has no periodicity, ie random pattern.
Would think direct injection pump would be continuous, so discounted that.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
You don't have a 1/2 dead hooker in the trunk, do you?
Cobrakit
Cobrakit
Southern Maryland
Ken
No, but i might have run over one.
These cars tend to have several mechanical noises, so you tend to get used to noises.
Zrussian13
Phoenix
If it sounds more like a rattle and happens around 2k rpms mostly in lower gears then its quite normal. There's a lot of rattles and ticks on these cars but I can't say Ive heard any groans. If the car is running and working properly I'd say leave it be. If I took my car to Ford everytime I discovered a new noise I'd never get to drive it.
Also when I start hearing a new noise I just drive the car harder for a while and they seem to disappear. These cars really seem to love the abuse! :crackup:
Cobrakit
Cobrakit
Southern Maryland
Ken
Not a rattle. It sounds like a groaning/moaning from an actuator. Problem is its random, not continious and only appears to be during driving. Sounds like something is running then stops.
Not sure what kind of actuators are on the engine? Also, don't think it could be a vacuum noise.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Groaning and moaning? Tell you passenger to get out. :wink:
You might be hearing the blend door actuators and dampers moving. Do you notice the noise when the climate is set to Auto mode? Put it on manual or shut it off and see if the noise stops.
br_an
Boise, Idaho
Bran
2016 Shelby GT350, 2020 Ford F150
can you post a video with the noise?
