sk47
- Nov 12, 2020
- North Eastern TN
- Jeff
- Chevy Silverado & Nissan Sentra SE
Hello; Have time to waste while waiting for a repair man. There is an old saw or feww about the poor always being around. Now that I think about I can see your off-hand dismissal as part of the green agenda. After all the "cost" of the green agenda is to be high in all areas. Only some will be able to make the purchases needed to live green. BEV's are expensive. The home charging units are expensive. The heat pump water heaters and more recently clothes dryers are likely to be more expensive than the old types replaced. I was with a friend when he bought one of the first "heat pump water r heaters". It was nearly double the cost of a standard type.Poor and middle class always get the short end of the stick.
At least with EVs their children won't be deformed and have mental issues decades from now.
Had the refinery tanks flooded, the water table would be permanently polluted. In addition, wildlife would be impacted at astronomical levels.
There is simply no comparison.
Sure the goberment* sent in Seal Team 6.
*fair game since you already brought in politics... before you say I'm "baiting" you.
A big row was reported in the UK over plans to force homeowners to replace their heating with heat pumps. Cost was a big part of the issue.
Hello; Contrary to your false claim flooding storage tanks will not necessarily make them leak diesel. After all the tanks are sealed well enough to hold in the diesel fuel. Mere flooding would have water outside and diesel on the inside of the tanks.
Thing is the flooding happened in a different state: Florida.
Hello; He did not say the "goberment" sent in forces to burn diesel storage tanks. Speculation that some climate zealots might have done so in a twisted bit of false reasoning.
Hello; Coal, oil and natural gas have been in continuous use for hundreds of years. For a long part of the time with no pollution controls. Lately with pollution controls. We are well into the time for dire side effects. Thing is the "green" and EV" agenda will have it's own set of pollutants released upon humanity. We already know of several. Add to those known the extra tire particulates due to the extra weight of the batteries. I have called it replacing one sort of pollution for a different sort.
One more point. The false notion that EVs will stop the use of crude oil. Not so, too many essential products come from oil. It will continue to be refined for those products. What will have to happen is some way to use up the gasoline, diesel, kerosene, and volatile gases. If these byproducts of oil refinery can be converted into nontoxic materials, then all to the good. If not, they become a toxic waste dumped into the environment. In fact, gasoline was just that in the earlier days. Dumped as waste before a way was found to use it.
