Gen 5 whipple tearing belts
Discussion in 'Forced Induction - 5.0L V8 Engine' started by 5ohcoyote, Jun 1, 2020.
  1. 5ohcoyote
    5ohcoyote Well-Known Member
    First Name:
    Nick
    Vehicle(s):
    2016 mustang GT
    Sep 5, 2019
    El Paso, TX
    71
    Occupation:
    Infantry
    0   0   0
    Has anyone else had issues when installing a gen 5 on a 15-17?
    ive contacted whipple, checked the spacers, checked belt size and tension and I’m still tearing belts. It’s currently 6 rib on 3.5 pulley. There’s one spacer for the tensioner pulley that’s a bit smaller it measured .36 when it should be .375, whipple said that shouldn’t be the issue.
    I can get the belt to seat right, but once I start it the belt gets pushed forward on one idler pulley and once I go wot the belt turns into a 4 rib.
  2. crcpdx
    crcpdx Well-Known Member
    First Name:
    Charlie
    Vehicle(s):
    Aug 12, 2018
    97008
    222
    102
    0   0   0
    IDK, I have an 18, but that sounds like a spacer issue.
  3. OP
    5ohcoyote
    First Name:
    Nick
    Vehicle(s):
    2016 mustang GT
    Sep 5, 2019
    El Paso, TX
    71
    Occupation:
    Infantry
    0   0   0
    That’s what I thought and whipple swore that wasn’t the issue
  4. crcpdx
    First Name:
    Charlie
    Vehicle(s):
    Aug 12, 2018
    97008
    222
    102
    0   0   0
    You could try a bigger spacer and see what happens. I remember a thread where guys just played with different spacers until they found what worked. If you were going to upgrade anyway, you could go the gates/ griptech route?
    5ohcoyote likes this.
  5. OP
    5ohcoyote
    First Name:
    Nick
    Vehicle(s):
    2016 mustang GT
    Sep 5, 2019
    El Paso, TX
    71
    Occupation:
    Infantry
    0   0   0
    *measured .375 and supposed to be .390. Just double checked. 523F914C-2D0F-4D41-AF16-0027E0853664.jpeg
    crcpdx likes this.
  6. db252
    db252 Equinsu Ocha
    Vehicle(s):
    16 GT Premium/PP/Nav
    Jan 1, 2016
    Bay Area, CA
    1,333
    714
    Rating:
    100%
    4   0   0
    Definitely an alignment issue. Go through the manual and double check every pulley and idler install.
  7. AZ_whippleS550
    AZ_whippleS550 Well-Known Member
    First Name:
    Douglas
    Vehicle(s):
    2016 mustang GT
    Jan 6, 2020
    AZ
    92
    One of those pulleys is for sure off, later I will take a picture of mine and post here.
  8. Avispa
    Avispa Well-Known Member
    First Name:
    Richard
    Vehicle(s):
    2016 Mustang GT/CS convertible
    Dec 5, 2019
    Oldsmar, FL
    328
    185
    0   0   0
    Doesn't happen often, but it does happen, Whipple may not have pressed the drive hub correctly onto the blower drive shaft. It doesn't take much misalignment to shred belts. Have seen that once in a blue moon on water pumps.
  9. dbranger94
    dbranger94 Well-Known Member
    First Name:
    Daniel
    Vehicle(s):
    Magnetic 2015 GT
    Jul 7, 2015
    Indiana
    266
    40
    0   0   0
    Not sure if you installed OPGs or a lower crank timing sprocket, but you may check the balancer is all the way back if it's ever been removed. You should also use a ruler or yard stick to check that all the pulleys, especially the grooved ones, are in the same plane.
  10. OP
    5ohcoyote
    First Name:
    Nick
    Vehicle(s):
    2016 mustang GT
    Sep 5, 2019
    El Paso, TX
    71
    Occupation:
    Infantry
    0   0   0
    Yup pretty sure it was the balancer. I was about to order the gates laser to see which one was off, but it was pretty obvious. Guess the last shop didn’t torque it down all the way after fixing my timing issue. Appreciate the help guys!
    TX-Ripper, sigintel and crcpdx like this.
  11. dbranger94
    First Name:
    Daniel
    Vehicle(s):
    Magnetic 2015 GT
    Jul 7, 2015
    Indiana
    266
    40
    0   0   0
    Glad to hear you got it figured out.
  12. FastCarFanBoy
    FastCarFanBoy Well-Known Member
    Vehicle(s):
    2013 GB GT
    Feb 21, 2016
    723
    489
    0   0   0
    Be glad it was shredding belts because that crank snout was probably not long for this world.
Loading...
Share This Page
