Gear swap?
krishelnino
Detroit, MI
Krishna
2018 GT Premium MT82 Race Red
I went from 3.73's to 4.09's at a total cost of $611 ($225 labor and the rest parts / tools / fluids) and at that price it was very worthwhile, but I removed and reinstalled the differential myself. It created additional force to the road from the rear wheels equivalent to if I had increased the engine torque by 40 ft-lbs. Normal dealer cost is around $1200 plus parts, 2/3 of the dealer labor time is removing and reinstalling the diff. In my mind the most important thing you can do is find someone you trust to install the ring and pinion into the housing.
How much would it cost on average for a straight pumpkin/carrier assembly swap? I have the 3.55 and looking at 3.73 Torsen differential carrier assemblies going for around 600ish.
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
All I can tell you is Ford dealers will probably charge you 8-10 hours of labor for it. Try a lot of places because prices for this are all over the place but if you don't use a dealer I'd try to find someone who has done it before on a 2015+.
krishelnino
Detroit, MI
Krishna
Ok thanks, i do have a very good local mechanic who works on a lot of S550s. He did a lot of suspension work on mine for reasonable prices. I'll try asking him. Is changing out differential easier compared to swapping gears?
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
It's much easier, yes. Swapping gears and setting the new ring and pinion is a process that requires knowledge and preferably experience. Failure to set the correct lash means you'll grind the gears to nothing or potentially blow up the diff entirely if you mess up bad enough. Swapping the diff as a whole unit is still annoying but more straightforward, gotta pull the axle shafts which means outer knuckles, brakes, driveshaft, and some other misc items. Takes a while.
Mikepol2
Pittsburgh, PA
Agree with @ice445, actually installing the ring and pinion correctly takes skill and experience that I don't think anyone can learn from a Youtube video. It's almost an art. But it took me about 5 hours to remove the differential the first time and another 3-4 hours to reinstall it after the new gears were installed, and I did it all based on stuff I learned online.
Sivi70980
Lacey, Washington
Mark
2019 Ruby Red GT PP1 M6
Actually getting quotes now from a few places in WA (home) and CO (current work site). If a CO place is cheap enough, I'll drive the car here for a bit and have it done. So far just one reply from a WA shop at almost $1600 to remove, change gears, and reinstall. Hope some other places can come in a little cheaper. Anyone know a guy in WA or CO? lol
krishelnino
Detroit, MI
Krishna
I just found a 3.73 Torsen carrier assembly locally for about 650. Trying to decide if should get 4.09 gears (more labor costs involved) or get it installed as is...i think even the 3.73 Torsen would be a decent upgrade from my 3.55 Trac Loc LSD right ?
Mikepol2
Pittsburgh, PA
All I can tell you is that I had the 3.73's with the Torsen and am happy that I made the switch to the 4.09's...I'd vote while you have it out get those 4.09's installed. Or save your $650 and use that on getting the 4.09's put into your existing differential, I think you'll notice the 4.09's more than the difference between the Torsen and the trac-loc unless you're tracking your car.
krishelnino
Detroit, MI
Krishna
I really wish you were closer i'd love to see how the 4.09 gears feel...yeah i'm planning on taking it to more track days this year or probably next, so i was eyeing the Torsen as a decent upgrade. Beside i hate how the Trac-loc doesn't put down the power properly on bad surfaces during turns
Vstang2
Jason
2019 GT
Any updates on your gears? I wanna swap gears as it appears the best seat of your pants mod for the 18+. I think a good tune with a little suspension work and a touch of better shifting would really make an 18+ with 4.09's shine.
AZ18yote
Arizona
Bryan
I would argue tuning for e is the best bang for your buck actually...
Sivi70980
Lacey, Washington
Mark
Well I didn't count E as it's not available to everyone , here in Tally we only have E10
Same for me, no E anywhere near my daily commute. Going gears and the ford power pack and calling it good.
AZ18yote
Arizona
Bryan
Fair enough. Then ya gears would result in more butt dyno satisfaction per $ vs something like the Ford Performance pack.
Vstang2
Jason
2019 GT
I've done some Steeda suspension work already , I'm thinking gears , a new shifter and gears will make a big difference. Swapping trans fluid to BG next week
