z06psi
- May 15, 2015
- Evans, GA.
- Andrew
- The pot stirrer
Nope. No fans or radiator.roger that, thanks for the info. sounds like it should be a fun night in the garage. gotta pull the procharger off to get to anything so thats fun.
anything else you pulled to make things easier? fan, radiator, etc?
A night?
Unless you have 6 people working on the car it is 8-12 hour job. I did it all myself and it should be around 12-14 hours. Breaks and the 4 hour bolt didn't help.
Just the gears. Oil pump assembly was easy. They slipped right in. In all the installs I have seen there has not been any clearance issues. Just gotta make sure they don't bind when installed.also, did you buy just gears, or you buy the whole oil pump assembly?
if you bought just gears, how was the install into the pump? i heard you have to clearance them or something.
