Gear Change from: 3.73 (Rear Gear) to: 4.11 in my GT350
Jossyfilms
Inland empire
Jose
2018 orange fury gt350
Been searching all over but can not find any info on which way the crush spacer goes
WD Pro
United Kingdom
Lime GT
PM me your email - I can send you the rebuild instructions when I’m back on my work PC :like:
WD :like:
Kidroc2133
Augusta, GA
David
2017 Mustang GT Premium Performance Pack
Could you also send me the rebuild instructions? Going to try and do the gear change this winter.
WD :like:
WD Pro
United Kingdom
Lime GT
You should have the instructions now, but so the info is on this thread :
WD :like:
Jossyfilms
Inland empire
Jose
Did you get the gears swapped out? Curious about your impressions.
Had the gears swapped out for a few months now and you definitely notice a difference in acceleration. The only issue I seem to have is when driving at normal speed the clutch seems to be a lot more sensitive to shift or atleast it’s harder to shift smoothly now
Champale
2020 GT350R
Hey thank you for that update! Do you have any increase in gear whine from the differential? I've kind of gotten used to the factory 3.73 gearing but still have the FRPP 4.09 kit sitting on a shelf.
Jossyfilms
Inland empire
Jose
There’s a very slight increase in gear whine but I only notice it with the exhaust valves closed and even then I can barely gear it
MAV
Arkansas
Mark
2016 Shelby GT350
Check my writeup on 4:56 gears and what I found out about the issues with shifting after a gear change:
https://www.mustang6g.com/forums/th...1-carbon-fiber-driveshaft.174916/post-3614488
