Gas leak
Classicnige
North Carolina
2019 Mustang gt
Anyone have there gas start leaking out of nowhere on the driver side part of tank?
KingKona
Virginia
Shlomo
2019 GT
That's why you have a warranty. Please let us know what is found when it's repaired.
Good chance something you ran over punctured the tank.
KingKona
Virginia
Shlomo
2019 GT
My warranty has expired sadly
Ford Extended Warranty every time. And this is exactly why.
Best of luck, it's probably not too hard to replace yourself.
69mach1-395
central nm, usa
2016 RR GT/CS
Could be the filler neck maybe? You need to find the source...
ORRadtech
Atlanta, Georgia
This. You need to know where it's coming from. Could be filler neck, return line, a bad seal or???
If you have a borescope you may be able to find the source with that. If you have to drop the tank, or have it done, try to have as little fuel as possible left. A full tank is heavy and awkward.
Classicnige
Classicnige
North Carolina
2019 Mustang gt
It’s only with a full tank of gas I’ll get it up in the air once I gets some days off I hope it’s just a gasket.
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
You can also remove the back seat cushion and access the top of the tank through the rubber covers over the fuel pump and sending units. A bad O ring seal could cause the leak.....
