Gas door flap?
Emt1581
PA
2017 Magnetic Mustang GT w/PP & TurboBooster Seat
I wasn't sure what to call it but I remember seeing a flap at the mouth of the gas tank that folds out to catch drops of fuel instead of it running out onto the car. I've been using paper towels there but is there something aftermarket that I can install to do the same thing?
Thanks
michail71
2018 GT 401a A10
An aftermarket part? Sounds like a good idea. This capless design makes it harder to not spill a few.
Emt1581
PA
i just tilt the nozzle up as i remove it.. never had an issue
For me that doesn't work. The hinged door inside the mouth almost pushes the nozzle out and that withdrawal sometimes spills a drop before I even angle/move it. So I'd like to have something there that does exactly what a flap would do to catch it. I think Porsches have them or did in the past. But it doesn't seem like it would be that hard to make.
Emt1581
PA
Anyone?
There are so many aftermarket parts for this car that it boggles the mind. Is this one area that there's just not??
Thanks
Zelek
Hutto, TX
2021 Mustang Mach 1
It also says to wait 10 seconds before pulling the nozzle away on the gas cover. I've done that and never had it drip on my paint. I've just taken a paper towel if any got around the capless area if there was a drop or two.
OP, just try waiting a bit after it clicks, then tilting it up a little as you remove it. That's really the best way to approach this.
Kep4
Jaeger
S. Kalifornia
'19 Mustang GT PP1
NightmareMoon
2016 Mustang GT PP w/ Voodoo
just wait 6 seconds before pull it.
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
I just filled my 17 and it has a very small drain hole below filler that the drips run to.
Kep4
Jaeger
S. Kalifornia
'19 Mustang GT PP1
69mach1-395
central nm, usa
2016 RR GT/CS
I just yank the nozzle out very quickly and watch the drops hit the ground...
jasonstang
Denver, CO
2017 GB GT/CS 6MT
I just grab a paper towel and fold it to catch the drops and toss it.
