Fuse for fuel pump keeps blowing with Lethal BAP
Brandon91
Forest City NC
Brandon
2018 Mustang GT A10
I fixed a boost leak today on my 18 that has a Procharger on. It was a small leak causing a few psi loss and now It keeps blowing the fuel pump fuse. The kit comes with a 40amp fuse but the directions say for 15+ that changing the fuse under the hood isn’t necessary. Should I change the fuse to a 35 or 40? is there a direct replacement fuel pump that doesn’t require a BAP?
thanks in advance
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Ummmm heck no. Unplug the LETHAL BAP and see if that fixes it. IF it does, get a quality VMP BAP.
Jackson1320
California
Jaxson
2015 mustang gt
thanks in advance
A dw400 fuel pump
Walbro 400, 450, 500, 525, 535
beefcake
Bethel
2018 Ford Mustang
i would try a 40 and see if it continues
Brandon91
Brandon91
Forest City NC
Brandon
2018 Mustang GT A10
I did and it still won’t run now.
I found that the power control module relay was bad after posting my original post. I replaced it and car drove fine for an hour. After that it died again.
beefcake
Bethel
2018 Ford Mustang
it is possible some of the wiring melted, if it got overheated
