Fueling upgrade needs for E85 Whipple?
AEF42
South Carolina
Andrew
Planning on adding a Whipple stage 2 to my
18 Auto. What upgrades would I need to run
E85? Looking at maybe 800 Hp max.
Devil5oh
Glendale, CA & Phoenix, AZ
2017 GT
Fore innovations fuel system and custom tune from Lund, PBD or AED. Or Bama if you want a blown up engine
AEF42
AEF42
South Carolina
Andrew
Thanks Devil5oh
Would it require a return type fuel system?
What Injectors options would fit this build?
engineermike
La
2018 GTPP A10
800 rwhp may not even require e85. The supplied fuel system, a pulley swap, and a can of boostane might get there.
AEF42
AEF42
South Carolina
Andrew
engineermike
I don’t know? I was thinking more HP from fuel and a little less boost would bring more reliability?
I’m currently on E85 and the engine loves this Fuel...
Boduke0220
NC
2015 GT PP
I ran deatswerks 95lb injectors and a Sai Li fuel system on 15psi with my whipple. Ran good
Kona 18
2018 Mustang
There are a few people running a BAP with the DW400 pump the stage 2 comes with and it's enough fuel for e85. This may be a cheaper option depending how much boost you plan to run. How ever a fuel system is normally recommended over a BAP'd single pump set up.
Tons of places are doing sales right now too, so shouldn't be to bad trying to find a deal on one
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
engineermike
I'm in the mid 700s at the wheels on 93 octane with the Stage 2.
For e85, a BAP and bigger injectors are needed and then a custom tune. Whipple is about to release a stage 3 kit which will be flex fuel, so you might want to wait a few more weeks until they get that kit on the market.
Take12
GA
2017 GT Base A6
Fore System or piece one together. I bought my hat, rails, regulator and FC3 from Fore and finished it off with an ID 750 filter and RHP 235 hose/hose ends. ID1050x injectors or Fuel Injector Development 1100cc. I use the Fuel Injector Development 1600.
Devil5oh
2017 GT
Thanks Devil5oh
ID1050x minimum, ID1300's would be a better bet for the long term but the 50x would be adequate
Kona 18
2018 Mustang
On a 2018+ ID1050's are more than enough, they're barely at 45% IDC on 15psi(Vortech JT-B). This was on a return style fuel system with dual regulators, 40/60 blend, HPFP was around 75% duty cycle(85* lift angle).
AEF42
AEF42
South Carolina
Andrew
Thanks for all the Input. I appreciate all the help.
I want a safe system without overdoing.
That being said this system that Hellhorse is
about to roll out. Does this look like it would work
without any shortcomings or should I put more
Into it like a Fore System?
Product Description
  • Hellhorse® 900HP Return Style Fuel System
    *Pre-Order Now Open, Orders begin shipping on or before December 8th,2018*
    - Twin Pump Return Style System
    - OEM Dual Pump Top Hat Assembly
    - E85 Rated Fuel Line
    - Black Anodized Fittings and Fuel Rail Adapter
    - Fore Innovations F1i Fuel Regulator w/ Pressure Gauge
    - Pre-Built Wiring Harness and Relays
Take12
GA
2017 GT Base A6
Sounds similar to the Sai Li and Rode Heavers kits. I see no reason why it wouldn’t meet your goals.
Kona 18
2018 Mustang
Looks like what you get from everyone's kit who uses OE hats that have been modified for return, few companies offer them, they are very economical since the OE hat is usually 1/2 the price of the billet ones.
olaosunt
Indiana
Wish some one would come with a kit to convert the GT 350’s stock dual pump to a return system .
