Fuel Rail Fitment
pittzy23
Wisconsin
Corey
2020 Mustang GT
Does anyone know if the Fore fuel rails for the 11-17 Mustang GT (Fore-18-900) could work or be modified to work on the 2018+ GTs? I can't visibly see any differences between the 18-900 and the 18-902 rails online. I got a free set of rails from my buddy who has a 14 GT, so if i can subtract 250+ bucks from the fuel system i plan to build that would be ideal. thanks!
bauern
somewhere else
Robert
F150 Powerboost
I would imagine that the 2018+ rail have the extra outlet for the high pressure fuel pump.
pittzy23
Wisconsin
Corey
2020 Mustang GT
that's what I was thinking too, but the older fuel rails do have a 1/8 NPT port on the rail that i would think would be able to accommodate that sensor. I'm trying to find the thread size for that sensor, but worst case i would think i could use an 1/8" NPT male to XX female adapter.
bauern
somewhere else
Robert
F150 Powerboost
The HP fuel pump inlet uses typical Ford push on hose ( not threaded). You'll need to see if there is push on AN adapter for the HPFP inlet, then run hose to the npt port on the fuel rail.
The adapter might be the same as the one used on coyote swaps.
