Upgraded Fuel Rail - Mustang GT - Boomba Racing
Status
Not open for further replies.
Boomba Racing
Wood Dale, IL
www.boombaracing.com
2015 Mustang Ecoboost TY 6MT w/ PP
---UPDATE---
Available now!
Link: http://www.boombaracing.com/2015-mustang-gt-fuel-rail/
We've been going through different renditions of a fuel rail upgrade for the Coyote. Some features that our rail will include are: centralized fuel distribution , AN-8 threads, end ports on both sides of the rail, larger bore diameter, and all stainless hardware. Check out some of these teaser pics below.
z06psi
Evans, GA.
Andrew
The pot stirrer
Just my opinion. I think you guys should have put the crossover in the back. Would have fit other manifolds.
CLDS550
Enterprise, AL
15 GT Premium PP
I agree!
Boomba Racing
Boomba Racing
Wood Dale, IL
What are you using to internally diffuse the "jet" at the entrance to the primary rail ?
What exactly are you referring to? Where the fuel enters the rail from the vehicle feed line? The pressure and flow is regulated by when the injectors are opening and closing.
Does it work with STB?
Yes this will clear the strut tower brace with no issues. Our tester had the performance pack and the OE strut tower brace.
With different style fittings, this could easily be made to work on a vehicle with a higher intake manifold. You could also put the crossover in the front or back due to pre-existing plugs already being in the rail.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
Subbed, in for pricing and availability.
Boomba Racing
Boomba Racing
Wood Dale, IL
Looks shiny enough, but what does it do that's an "upgrade"?
These rails feature a larger bore diameter than stock to allow more flow. This makes it even easier for the rail to accommodate larger injectors and be perfectly fine to run full E85. They also allow the end user a lot of customization for different feed/return style set-ups. There are ports in the middle, front, and back of the rail to allow you to set up the lines in endless possibilities; out of the box is direct plug and play. We also have an NPT port on the rail which will allow you to run a fuel pressure gauge should you want.
Boomba Racing
Boomba Racing
Wood Dale, IL
Will this work with the gt350 IM or the Holley Sniper IM?
The crossover section may need to be longer, but it physically should fit. We have not yet had a Mustang in with either of those set-ups to test/confirm fitment on with either of those manifolds.
Status
