Fuel pump hoses
Jackson1320
Jaxson
2015 mustang gt
  • Thread starter
  • Banned
  • #1
The fuel pump in the s550 has two hoses attached to it does anyone know what the second hose is for
Slopoke
Left Coast.
Ed
2019 Mustang GT PP1 10R80
It's to operate the venturi/siphon system that draws fuel from the R/H side of the saddle tank into the L/H side. IIRC, it also keeps the fuel basket filled with fuel.
Jackson1320
Jackson1320
Jaxson
2015 mustang gt
  • Thread starter
  • Banned
  • #3
Why not install a pump on both sides of the tank. Seams like a easy way to upgrade the fuel system
illtal
You would need a controller or some kind of way to turn the other pump off when the saddle is empty or at the very least low enough to not cool the pump anymore. A small lift pump would work if you can figure it out.
Jackson1320
Jackson1320
Jaxson
2015 mustang gt
  • Thread starter
  • Banned
  • #5
Run a return style that returns to both sides?
illtal
I think you still will need to turn it off with a low fuel level. If I'm not mistaken the fuel level on the other saddle is averaged with the active saddle to get the level.
Hmmm
Jackson1320
Jackson1320
Jaxson
2015 mustang gt
  • Thread starter
  • Banned
  • #7
Hmmm
Ok so not as easy as thought. But if you pull out of both sides and return to both sides might work. You keep the sending units
illtal
The best thing to do would be to increase the venturi effect of the jet siphon. That way you're not heating fuel, making the system more complex, adding another electric load and you're not creating extra hose. Aeromotive and radium are the only two companies I know that make aftermarket kits.
I have an idea for a pump system that would work well but people are cheap.
sigintel
Ray
2018 GT
I snagged an extra stock pump basket to do exactly that. Was gonna set up a microcontroller and watch fuel level sensor for each basket.
inputs: port and starboard individually : level, temp send/return, current, voltage in/out (regulator), RPM?
outputs: port pump OFF/ON12V/ON18V, starboard pump OFF/ON12V/ON18V, pump startup bypass (dumps fuel at 0psi direct back to tank during startup current surge? or possible use PWM to soft start /current ramp)
Could also control two valves on a reverse Y from the return fuel to decide which side receives the return line fuel.
