Fuel pressure gauge orientation
Discussion in 'Forced Induction - 5.0L V8 Engine' started by Bmaughan, Mar 9, 2020.
  1. Bmaughan
    Bmaughan Well-Known Member
    First Name:
    Ben
    Vehicle(s):
    2015 procharged mustang gt
    Sep 26, 2019
    Az
    328
    Any issue with running a fluid filled fuel pressure gauge horizontally ? It’s the only position in my set up but it seems it will work… But I’ve not seen anyone run it this way so I just wanted to be sure it won’t cause me any problems
  2. Jay-rod427
    Jay-rod427 Well-Known Member
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,293
    865
    Rating:
    100%
    4   0   0
    Run it any direction ya like
  3. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    Awesome.. thanks man!
  4. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    One more question if you don’t mind.... this is probably a stupid one, but do you see any issue with running the dial gauge and a cheap analog pressure sender on a t fitting like in the picture?
    I didn’t know if they could potentially interfere with one another being so close...
  5. Jay-rod427
    Vehicle(s):
    2016 GT C/S
    Jun 8, 2016
    Kansas
    2,293
    865
    Rating:
    100%
    4   0   0
    No issue
  6. lx347cd
    lx347cd Well-Known Member
    First Name:
    Tony
    Vehicle(s):
    2017 GT and 2003 Cobra
    May 10, 2019
    PA
    105
    Occupation:
    OEM Vehicle Engineer
    0   0   0
    don't run a fluid filled gauge.
  7. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    Why is that?
  8. lx347cd
    First Name:
    Tony
    Vehicle(s):
    May 10, 2019
    PA
    105
    Occupation:
    0   0   0
    , A liquid filled pressure gauge is very susceptible to heat, changing its reading with the temperature of the gauge.
  9. lx347cd
    First Name:
    Tony
    Vehicle(s):
    May 10, 2019
    PA
    105
    Occupation:
    0   0   0
    Unless your using the pin style aeromotive type and if that is the case it requires mounting so the face of the gauge is perpendicular to the ground, and with the pin-valve/plug assembly on top.
  10. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    Interesting... I only really use it to set base pressure. I do notice it’s about 3psi off from the cheap transducer I also use. Its an amazon special so I just assumed it was wrong and the gauge was correct..
  11. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    The one I have is an aeromotive...what do you mean by pin/valve? Why would it’s orientation mater?... I kind of thought it might but I have heard otherwise on this thread.
  12. lx347cd
    First Name:
    Tony
    Vehicle(s):
    May 10, 2019
    PA
    105
    Occupation:
    0   0   0
    If its the aeromotive pin style which it looks like it is then yes it supposed to be mounted the way i describe. Its on their website.
  13. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    Shoot... that sucks.
  14. OP
    Bmaughan
    First Name:
    Ben
    Vehicle(s):
    Sep 26, 2019
    Az
    328
    For what it’s worth... I did some reading and it seems the only reason the orientation matter for the aeromotive pin valve style gauges is the actuation of the pin valve itself. Since I’m only using it for setting the base pressure the gauge doesn’t get that warm in the time it takes to do that so I think it should work fine.
  15. illtal
    illtal Well-Known Member
    Vehicle(s):
    Nov 16, 2018
    302
    48
    0   0   0
    Fluid Gauge in the bay is better than a regular one the vibration kills the non fluid filled ones. Also you should be able to run a sender off of it if you want to.
Loading...
Share This Page
