Front door speaker adapter rings?
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
Does anyone know which speaker adapter rings would fit the base front door and rear door speakers?
I bought these:
http://www.crutchfield.com/S-cQ8RD0qqqG9/p_2064CS674/Kicker-40CS674.html
When I opened the door panel and tried to install today the 4 holes in the kciker speaker wouldn't fit on the door (I was going to drill the 4 holes)...
But what was happening was that speaker opening in the door was too big for the size of the speaker.
Does anyone know what hardware I need to install these in the door. Aside from a custom cut piece of MDF.
gundam83
Sacramento, CA
2015 Mustang GT Oxford White
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
I just bought these for my upcoming install. Haven't received them yet so I can't tell you if they fit or not but I'm guessing they should. Worse case scenario I drill new holes but use these adapters anyways. I don't have access to a jigsaw to make my own and I don't want to use MDF because of moisture.
http://www.crutchfield.com/p_120825605/Metra-82-5605-Speaker-Mounting-Brackets.html?tp=2824
I was just on the phone for quite a while with crutchfield. They assured me it would fit. I ordered 4 of them as well.
They should work fine hopefully!
mumbles
ATL
Eric
'16 GT Prem OW
Moisture can be a problem... spray the mdf with rubberized undercoating to protect against that or use some cutting board material that you can get at Target or Home Depot...
Marsupilami
Austin, TX
2015 V6 Fastback
Hey Pumxee, did these finally work out for you? I was thinking about ordering these as well as the 72-5602 cable harness (somebody already verified this here). I'm leasing the car and want to avoid drilling/cutting anything.
On the metra website the pictures show that there are two kind of plates opposed to the picture on crutchfield. There is a raised one which supposed to match the rear positions but also there is a flat one, are those like fit together? How this looks in the kit that you got? Isn't the height of the plate a problem in the front door? Normally the rear speaker is raised but not the front one. How many kits did you order?
Thanks
dullishpage
San Francisco
2015 Mustang Ecoboost
Thanks
I also would like to know this, as i just bought speakers and im in the same boat.:ford:
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
The adapters worked but I ad to cut the tabs that were coming inwards. I dont understand why metra made those. It made things more complicated.
I am going to be trying some wooden speaker adapters now.
mumbles
ATL
Eric
'16 GT Prem OW
Since the doors have a lot of moisture, I would definitely try HDPE (cutting board) over wood/mdf. It cuts as easily as wood, doesn't give off dust like mdf, and is already waterproof. This is if you are making your own...
dullishpage
San Francisco
hey were using a amp for the door speakers or no, sorry if you said this somewhere already. IF not, notice any difference?
Marsupilami
Austin, TX
2015 V6 Fastback
Hi All,
I haven't replaced the speakers yet and won't for some time now, but I got the speaker adapters so here are a few pictures if you're interested.
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
Hi All,
You see those tabs inside. You will have to cut those out. I dont know why they put them there
Quackfoo
North East
2016 Black GT Premium
Just something I learned using those rings on other cars, you might want to get some thin weather stripping or felt strips to put between them and the door. Sometimes (not always) they'll vibrate against the metal of the door if you crank up your stereo.
