Hack
- Nov 26, 2014
- Minneapolis
- Mustang, Camaro
One thing that hasn't been mentioned in this thread is that Ford recommends only adding oil if the level is below the bottom marker on the dipstick. My GT350 would disappear some of the oil if it was filled to the top marker. However, it would only consume oil down to about midway between the marks on the dipstick.
If I left it alone and didn't add any oil, the engine stopped consuming oil. Once I figured that out, I never had to add oil between changes again.
So my question to the OP is whether you wait to add oil until the level is below the bottom marker on the dipstick? If not, I suggest you try it.
One other thing - if you don't have obvious leaks, the engine is probably burning the oil vapors. It doesn't take much oil per combustion cycle to add up to a quart between changes.
