Sold: Canada - Ontario FP Oil separator relocation kit $40 US (+$20 shipping)
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I just realized my oil separator for my 2016 does not have the provisions for the bracket. :(
Yeah I need to check mine first, too. I used a basic household L bracket and screwed it to a hole I drilled into the plastic valve cover. IOW I used the FP separator from my 2016 car since it was cheaper than trying to resell and replace it.
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Thank you for letting me know.
Based on this info the 2015-2017 M-6766-A50 doesn't have the 2 mounting channels.
My bracket is only compatible with M-6766-A50A for 2018 and up.
Revising my info.
Still waiting for bracket supplier quote. 🐌
Seanuf99
St Louis Area
Sean
2021 Mustang GT
Revising my info.
Please add me to your order list if your supplier comes through.
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
UPDATE: I have received my vendor quotes and have started procuring components for 10 kits.
I was able to keep costs the same, so no price increase! :handsinair:
Here's the list of members I have down for kits so far. Kits are made one at a time and will be offered (in the following order) to those members that have stated they would like one:
@Brazos609
@jpg393
djpayne2
Cranston, RI
Dennis
2019 Eco Premium
@Brazos609
@jpg393
@Seanuf99
Please add me to the list. I don't need it for any fitment issues, I just think it looks better moved and looks easier to service. Looks awesome. Thank you.
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Hello. Added you to the list.
Yes, this kit makes it much easier to service in the new location.
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Brackets are in production.
Gates heat shrink clamps are in.
Project
U.S.
'21 Mustang GT Prem
I'm in for a kit, please add me to the list, thanks.
Mach1man
New York City
Brian
2021 Mach 1 2001 Bullitt Mustang 2001 GT Mustang
Would this kit work on a Mach 1 application ie. Bullitt intake engine?. If so I would go for a kit.
thanks
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
thanks
It should but Ford might have moved a few things around on the Mach1. Please check the area shown in these pics from my car. Notice how the corrugated plastic loom drops down by the wire harness? If your car looks like this then you won't have any issues installing.
Tones GT
Erie, PA
2015 Mustang GT PP, 2021 FJG Mach 1
Would this work with a Whipple on a 2021 Mach1? Attachment to the Whipple is almost same location just on the front of the supercharger itself.
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I would say probably with a slight alteration. It looks like the long hose would need a 90deg fitting at the intake side instead of a 45deg. As I do not have access to a Wippled car, I have no way to verify the length of the intake hose or proper orientation of the fitting. I can supply a slightly longer hose and leave it up to you to trim it back with a cut-off wheel or not. You will also need one of the 90deg fittings to snap onto your intake. I recommend you preserve the hose that came with your Wipple kit. Not sure if these are even the same fitting size as the Ford version.
Mach1man
New York City
Brian
OK, I'm in looks like it will fit a 2021 Mach 1 without issues. Please add my name to the list.
Thanks, Brian
StangTime
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Thanks, Brian
Added you.
Still waiting for the brackets to come in... 🐌
