ForScan not Connecting
mainemaine89
Jermaine
boss 302
hey everyone i cant connect to forscan i keep getting a ELM not found code, check your connection and try again has anyone experienced this problem
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
You may need to install the OBDLink drivers. Does the LED on the interface light up red or yellow when you connect it to the computer? Red means drivers not installed. Yellow means everything's fine, ready to connect to the car.
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
There is an update on the forscan web site. My tuner had to download it in order to enable bambi mode, dark mode and disable double horn honk on exit.
StickShiftyFifty
CA
2016 mustang pp
I heard you have to load stock tune on first before connecting.
Elp_jc
None
Is this the first time you're using FORScan, OP? If yes, then you either have an issue with the software, or have an incompatible OBD2 cable. If not, then most likely your temporary (2-month) license expired. In that case, just download a new one. Good luck.
