Foot brake technique with twins
awdtsi
Toledo
2015 Mustang GT
So I was wondering what some of you guys that pull low 60 foot times do to launch your twin turbo cars? I have a Boostworks kit with Comp 6062 turbos and a Circle D 3B 258mm converter. I came from an AWD 5 speed drag racing background and my first time at the track with my Mustang left me feeling like my 60 foot times were pretty bad.
My problem was that I was pulling through the brakes while trying to build boost. I was only able to cut 1.65 60' times and ran a 10.2 @ 140. My question is how do you guys foot brake effictively? Do you hold to a certain rpm and flash it or can your brakes hold back the car with your foot to the ground? I'm new to auto drag racing and any tips would be appreciated.
Thanks
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Thanks
Time is respectable.
drive_55_not
S,East
2014 Coyote, S197 3v, 2018 Gen3 [RIP], 2020 Challenger 'Cat
Thanks
You'll barely build boost trying to foot brake before you start blowing thru the brakes ... You need a transbrake to really lock it up ...
You could add a 2-step, that'll let you get a little more rpm on the converter foot braking ...
3beeps
www.instagram.com
'17 GT
I have the same issue you do. Twins and a 2B converter. On the 2-step, I push through the brakes at 3000 RPM once the boost goes positive.
I've added a 2-relay transbrake so that should solve the problem. I'm surprised you push the brakes with the looser 3B converter.
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
I can only get about 3200rpm out of my 3B before it starts to push thru... Transbrake is the answer!
Dennisn
Chicagoland
16 gt
I’ve been footbraking for almost two years. 3b with two step. Usually 60 low 1.5 and 1.4’s. I’m gonna try the tb and see if I can’t get consistent 1.3x’s
awdtsi
Toledo
2015 Mustang GT
What rpm do you hold it at?
Dennisn
Chicagoland
16 gt
With two step push hard on brake and floor it. Wait second or two. Let off brake and she goes. If I’m on it long enough it’ll build 4 lbs of boost.
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
You need MSD 2 step @ OP!
olaosunt
Indiana
Consider the aerospace double calipers for the rears.
I have a 2B converter and I can now build 7 psi on the foot brake with the 2 step set to 3700 rpm .
gimmie11s
SoCal
Murica!
Guys what wire are you tapping for your MSD 2 step off the brake pedal on the auto cars?
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Did you ever figure out which wire to tap into?
I use the brake light switch positive wire that sees 12V when you press the pedal, that way when foot braking 2 step is active!
hawk232
Crystal River, FL
2016 white GT premium
I have footbraked a 1.45 60' before i put the 2 step on. stand on the brakes and slowly bring rpm up. Highest "boost" I saw was 0.0 or 0.1.
Put the 2 step on and have now seen up to 5psi without a transbrake. Only been to the track once but had other issues so no times to report.
3beeps
www.instagram.com
'17 GT
I had trouble pushing through the brakes on the 2step and footbrake. I wonder if its because I have a 2B and you have a 3B.
