Flex Fuel Tune and Boost
ATTFighter
Will Flex Fuel Tunes eventually be coming out for supercharged applications?
Sent from my SAMSUNG-SM-N920A using Tapatalk
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I asked Lund while he was doing my revision.
[/URL][/IMG]
ATTFighter
Thanks
beefcake
Bethel
2018 Ford Mustang
yep, at some point, they are testing on their car
kiko1
Miami, Fl
2015 GT auto
it would be great if we could do it with an actual flex fuel sensor added in like the cheby guys do.
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We're testing the Lund Racing Flex fuel tune on our Whipple powered GT. We should have some results shortly. I'll post up once testing is finished.
LethalPerformance
Fl
BOOM! Will this require full fuel system?
We're running ID1000's and a JMS fuel pump booster. I believe if we keep the boost under 11psi we should be fine however that hasn't been confirmed yet.
So at the moment I can't say for sure whether what we're running is 100% adequate or if it will require a return system. I'll know shortly.
Thanks, Jared
mustang_guy
United States
it has an engine!
I hope its possible to put a pid for ethanol content and change the wideband to read lambda numbers. Thatd be ideal.
sonic
NY
Prius
Thanks, Jared
As Always thanks for the insight Jared:cheers:
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
beefcake
Bethel
2018 Ford Mustang
we usually recommend a stage 1 fuel system, but, i have seen guys push it pretty far
Sikksohc
Buffalo ny
'16 gt premium pp
[MENTION=10926]beefcake[/MENTION] is it true Lund won't tune e85 with just a boost a pump? And if that's the case this flex tune with boost probably won't be available to us unless we run a return setup
beefcake
Bethel
2018 Ford Mustang
correct
