Flat Plane Engine Vibration?
Rhumbline
DMV
2001 BMW M3
Quick question for you new GT350 owners: flat-plane V8s have been avoided due to high(er) vibrations levels than bent-crank V8s.
So, just how much higher is the vibration levels compared to, say, a regular 5.0? Is it noticeably buzzier? Four-banger level thrashy? Or only a bit rougher than a regular V8?
NOT that it really matters given what a stupendous motor this is otherwise, just kind of curious from a technical standpoint (and maybe being a turbine-smooth I6 M3 owner spoiling me in the NVH realm).
Bossing
attacks tracks
So. FL
Just can't get enuff!
At the higher RPM's there is noticeable vibrations & harmonics in play... you'll clearly feel and realize this at the track, i.e. HPDEs, where the higher range of RPM's are continuously sustained. So far I think FP did a good job in the development... no loose parts or rattles in my cabin but I do feel the vibrations. Feels leery/strange in the beginning so it's something different to get accustomed to.
mattlqx
Driver
Mesa, AZ
It's a very even vibration. Something akin to what the vibrator in your phone produces. I notice it most in the gear shifter, but that's really about it. From a cockpit standpoint, most people aren't likely to notice any difference.
DaveH
2016 GT350 Avalanche, Tech Pack
It's honestly not that significant, I only notice it in the shifter at higher RPM's. For comparison, my Ferrari was significantly worse through the cabin/shifter but it's just part of the character.
HizliBullet
GT350
Canada
Mustang
16 GT350, 17 Edge Sport
((YEESS...)))
but with the appropriate engine mounts and firewall you wont tell the difference in 5.0 and 5.2
Shawnski
GB WI
Whatever I need
I first read about the vibration from the recent C&D issue comparing the GT350 to a Z51 'Vette.
Since the GT350 has a two stage exhaust, part of their experience was no doubt influenced by the un-muffled exhaust rasp. I can attest to this with some of my 180 degree V8 hot-rods but its mostly heard and not felt. Particulariy with my Lightning that has stage 2 cams and 14 psi of boost with a full Bassani exhaust that sounds very belligerent, however the (balanced by JLR) .020 over 5.4 motor feels glass smooth through its rev-range. However, I have 2 other hot short deck SBF's with poly motor mounts and I feel a very low frequency vibe.
bretlasalle
San Francisco, CA.
2016 Shelby GT350R
Mine produces a pretty significant chatter, even at lower rpms - seems to go away as I accelerate. The comments have me thinking about going to the dealer to see if it's normal...
Hack
Minneapolis
Mustang, Challenger
It's like having two typical large displacement 4 cylinder engines attached together. You've heard the comments that 4 cylinder engines have a FPC? Well, they do. They also have similar vibrations. Not a big deal. The vibration is not unusual at all; mostly even mentioning it is something I would associate with a troll more so than any genuine concern or actual issue.
I think it vibrates more than a Coyote, and I would expect it to. But it seems higher quality than most 4 cylinder engines I remember. I owned a Fiesta and that was really smooth, but had a couple Jap cars back in the 90s that were pretty buzzy.
Grimace427
NoVA
2011 Mustang 5.0
With the Voodoo engine this is not exactly true. It would be true if we were talking about a Ferrari FPC. A typical inline-4 cylinder is arranged Up-Down-Down-Up, with a FPC V8 being Up-Down-Down-Up-Down-Down-Up.
The Voodoo is arranged Up-Down-Up-Down-Up-Down-Up-Down.
mattlqx
Driver
Mesa, AZ
It'd be more comparable if you were talking about a straight-8. But being arranged into a V creates forces on two planes instead of one, which would lead to more vibration.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
God forbid 8 massive pistons moving up and down create some vibration.
Rogue
Porsche 911 Carrera S, Boss 302 Laguna Seca, Jagua
:cheers:
A 6 speed F430 - not too often you see those either.
krt22
2016 GT350 Track Pack
Those are getting spendy now, same with the 6MT 360s
Rogue
Yup - I was shopping 360's last summer and the 6speed on both the 360 and 430 would fetch almost twice the price of an F1 - absurdly rare on the 430.
