First start didn’t run so well...
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
got install finished and first start, it wouldn’t run for shit. We realized we didn’t set the BAP. Don’t quite understand the instructions....
also got low oil pressure and a couple back fires.
Can anyone lend a hand with getting BAP set? I’m hoping this is the issue.
Maybe bypass it and see if it idles at all?
Thanks
gimmie11s
SoCal
Murica!
Got what install finished?
nowhere near enough info here to help you.
lack of BAP wont make the car not run.
Did you install OPG? Timing off?
need more info.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Whipple Gen 3, stage 2 with oversized heat exchanger.
Bypassed BAP And it runs fine. Need to be that dialed in.
Was waiting on oil to come, I think that why I’m getting low oil pressure.
I will get oil changed and see if low pressure light goes away, that’s my biggest concern at this point.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Sry, little flustered... JMS powerMax BAP.
moffetts
San Mateo CA
Black Whippled 2015 GT PP
What tune are you using? You don't need a BAP with the Whipple tune unless you're running a smaller pulley.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Lund requires a BAP to tune.
Crackerjack17
WV/Maryland
2017 GT PP
Low oil pressure when idling? Or was engine trying to barely idle and threw oil pressure light? The oil pump is crank driven off the front of the motor, it either works or it doesn't. Any leaks anywhere?
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
After about 30 seconds it throws warning, I think it might be a tune issue. Car has oil.
No leaks so far, haven’t got car up to temp. Don’t want to run it with warning
xxchieferxx
lol@ mpg
Louisville Ky
Charles
2015 Mustang GT
Im guessing youre on the base tune from lund? Is your car a pp? Did you tell lund this? If its a pp car and you didnt tell them then it will throw the oil pressure code.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Fist tune from Lund, my car is not the PP, no center gauges
Boduke0220
NC
2015 GT PP
Low oil pressure light is normal. Mine had it, tell lund to fix it in the tune
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Above statements are correct in regards to low oil pressure warning. Lund gave you a PP tune and need to revert it to a non PP. there is also no issue running your car until then. The tune is looking for the input from the gauge which you don’t have and is causing that warning. Super simple fix.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Thanks guys, appreciate the help
ahl395
Allan
Agree with the oil pressure problem. Common thing with the base Lund tune.
As far as the BAP... The JMS isn't activated until a certain throttle percentage. So that not being set correctly shouldn't affect anything. Maybe the connection to/from the fuel pump was not good. Check the connectors/pins and make sure everything is tight. Settings on the BAP typically has it boost around 50% throttle to 18V.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
She is running! Just need to get BAP up and running.
