First Must do inexpensive mods?
fast88fox
Wilkesboro, NC
2016 DIB GT Premium PP
Mine looks like a bunch of the others....
Steeda clutch assist spring
JLT catch can
Redline hood struts
Steeda jacking rails
Window tint
Exhaust
Tires (I know they are not cheap but just about anything is better than the PZero's on my PP car)
Lowering springs
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Shifter Bushing
Clutch spring
WeatherTech mats
LED interior light kit
Trunk strap handle from SpaceCitySpy
Jack rails
Catch can
Yeah, that's a great list of easy to do upgrades that are all reasonably cheap.
Clutch Spring, absolutely! So much better, it's like a totally different transmission and it's a 5 minute swap.
If you plan on any under the hood changes, get the hood struts first - they make working under the hood _so_ much easier.
Shifter Bushing: $15 and 15min to put it on. Dramatic difference in shifting accuracy. Had an aftermarket metal bracket and bushing on my 2012 and this does the same thing for $60 less. Use the remaining money for a 6 pack to enjoy while putting the bushing on.
http://www.energysuspensionparts.com/4.1145
No shit? I've been looking for a little more improvement without going to a whole new shifter (and not adding any noise/rattle).
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Shifter Bushing: $15 and 20min to put it on. Dramatic difference in shifting accuracy. Had an aftermarket metal bracket and bushing on my 2012 and this does the same thing for $60 less. Use the remaining money for a 6 pack to enjoy while putting the bushing on.
+1, I have the same, though took more like 45 minutes.
max8544
houston tx
s550 yellow
Get the gas pedal spacer from spacecityspy.com to bring it closer to the brake pedal and much easier to heel n toe, only 16 bucks
Kinjirra
Kinjirra
I R Slow
Chapel Hill, TN
Brian
16 Ruby Red GT W/PP, 401a
This thread has really taken a life of its own.
I was really surprised nobody had made a "Top 5 must do Mods" "Or first mods..read this" thread and made it a sticky. Seems like it would help limit alot of the repetitive questions and help us n00bs out lol.
Omega
Ohio
2017 LB GT PP 401A, Roush 727
This fixes everything. :lol:
Semi
Utah
79 ford f250 7.5l/2015 gt pp ruby red
I don't even know what heel to toe shifting is and I bought one of those spacers. Great thread. Only other thing I bought was a ford racing knob but I've got my eyes on that lockout kit.
Forgot I just bought that shifter bushing too.
Can someone tell my why the gt350 wheel is better? Is it just looks? I know the one I saw had suede but I don't prefer that.
randotheking
Cincinnati
2016 Mustang GTPP
Definitely takes more than 15 minutes. It's actually extremely hard to install, I almost gave up and put the OEM back on. The Steeda Bushing on my 2013 was much easier. That said, if you can get the Energy bushing on, it makes a huge difference, but it's not perfect. My 1-2shifts are notchy, especially in the winter. It's much worse than my 2013 ever was. I'm going to add BG Syncro Shift II and see what happens
mikeD4V
MD
15 GT
Mileage varies I guess. Mine isn't notchy, just feels like a more accurate stock shifter.
Jack up the car, put ~12" of extension and socket on dewalt impact, buzz off the two 12mm(?) bolts, pull bracket off, slide stock bushing out, slide new bushing in, push bracket back on (use some lube here), put bracket bolts back in, drop car, drive. I did it a few times on my 2012 so maybe it just went quicker due to that. Hour tops, shouldn't take more than that. Same process as putting an aftermarket bracket in. Can't lose either way, aftermarket bracket or just bushing works well.
PJR202
KY
2016 GT PP Shadow Black
Save yourself the 15 bucks and just ditch the clutch spring altogether. If you don't like the feel after that, you can always order the steeda.
randotheking
Cincinnati
2016 Mustang GTPP
There's a lip on the shifter that the Energy Suspension bushing has trouble getting over, its a pretty common problem on these forums. I think I got lucky after my 10th try and it finally slid on. My upper body was super sore the next day from trying to do that while under the car
