First GT500 in the 9s
V00D00
Dover DE
2020 GT500
What is the stock boost on these gt500’s and what was this one hitting??
Stock is 12, hard to say what psi he was seeing. He is running a 2.65 upper, good for 17 psi, but also ported blower which would drop measured psi 1-2lbs
DeadSpool
Fort McMurray, Alberta
2016 GTT
Thanks man... I just read Lund’s reply on IG. 16 when doing that pass and a little bit higher when it was on the dyno.
BlackandBlue
Mustang
****Correction ****
Just got confirmation Lund was slipping on the dyno, dont know at what power level
On that last run in the video the shifts sounds lazy.
Sounded like the shifts engaged slipped for a split second and finally pulled the Rpm down after some torque was removed.
Hi-PO Stang
Minnesota
2014 Shelby GT500
I want to see the battery moved to the trunk and then see the quarter mile times.
FruityJudy
South Alabama
2018 Mustang GT A10
On the first pass I watched it sounded like it was cutting fuel on the shifts, the rest of the passes it sounded like that was no longer the case. Was that changed in the tune?
Stage_3
MA
2019 Roush Stage 3
I think they're running these times in manual mode. Either DRAG or TRACK mode for some reason. Maybe because of the DCT? I'm not sure.
Also, I think the torque management is holding the car back still. Hopefully they get that issue figured out.
V00D00
Dover DE
2020 GT500
I can only speak on 2 things:
1- i made it known that best mph will come from manual and trackmode shifts, especially at 8k, or 8200 as i think they are doing
2- i would take everything any camp says with a grain, as some are more likely to put out false or half-truthed information, especially this early in the game.
Development and shop cars, by nature, are not cared for like our personal cars and there is a ton of $$ on the table if a few wisely chosen statements can sway opinions 1 way or the other. Look for in depth reviews and tech data and results
gmd2003
SC
GT350R
Very true , I sure as hell won’t be spinning mine to over 8k , in my opinion it’s a very bad idea and is only in play due to the tq management limiting gains at normal revs ..... won’t last on a track over revving under hard use . The only reason for Ford choosing 100 psi oil pressures is they are unsure of the bearings still.
ShelbySnake
MI
Mustang
That is not impressive...Not beating a Redeye in a drag race...Just a pulley and 93 tune and a Redeye will be doing 9.7's...All the work done to that car , do the same to a Redeye and Redeye does low 9's...The Redeye has gone 10.15 with just a drag radial and seat removal...Ford can have the road race course...I could not care less...The DCT will be an issue.
Once tuners can adjust launch rpm and calibrate the trans, Im sure a car with these mods will be deep in the 9’s.
Stage_3
MA
2019 Roush Stage 3
Absolutely brother!!!
Big monies on the table.
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
You've still got your shipping protectors on, hahaha ... !
IceAge
Virginia
GG
2020 GT 500, 2022 GT500, 2020 GT Mustang, Raptor,
I own a Redeye and the difference of the Torque Converter in the A8 versus the GT500 DCT not having one is the issue imo.
biminiLX
Sylvania OH
2022 GT500 and a few others
So the rule is anything reducing restriction before the blower rotors should INCREASE boost and anything reducing restriction after the blower should REDUCE boost.
For example, increasing the TB size will increase boost, while removing the cats will reduce boost.
The blower elbow behind the TB and before the rotor pack seems to be the biggest restriction from what I’ve seen.
It’d be interesting to see what porting gains Kong found.
I was assuming someone will eventually make an ‘elbow’ to replace the stock piece.
It will be complicated, but running a huge TB and reducing rotor pack would be worth it for max power.
On second thought, I’ll just take the 3.8 Whipple :)
-J
V00D00
Dover DE
2020 GT500
-J
Are u sure on that? Increasing the area would reduce the resistance, resulting in lower pressure, correct?
Anyway, he was running a 2.65, good for 16-17 psi, larger TB and ported blower
I have the 2.75 on now, and seeing about 15-15.5 psi
The orange car is getting tuned in a few, and he has the 2.65, so we will have some backup information
