Filter and fluid change
Piedpiper
Austin texas
Carl
Doing a fluid and filter change, how many quarts and what type of fluid do I need, thanks.
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
Go with the Ford recommendation on oil weight and filter. And if you tick, the additive.
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND, Ford S-Max 2nd series, Lancia Y
What it is? Hide and Seek?
Please give us a little more information. I guess you are talking about the 10R since you mention filter.
You have to use the Mercon ULV, add 5 quarts then start the engine. When hot (very hot) check the level with the engine running, should be between 4 and 5 or the letter "A", depending on the dipstick. Use protective gloves not to burn a hand.
The bolts on the filter are rated at 10Nm, be careful one is longer than the other, do not confuse them.
On the pan stutbolts are rated at 12Nm while bolts at 10Nm.
