akmon
Good evening
Last week I decided to have the fluid of the 6R80 transmission box changed at an official Ford dealer. Although Ford says it should be changed every 150,000 miles, on the recommendation of many owners, I've wanted to change it at 36,000 miles.
The guy from Ford was very kind and allowed me to be present throughout the process at all times. Removed transmission pan, cleaned 2(!) magnets, changed filter, new gasket and bolted back on, then added LV fluid, started car, shifted to all gears, added more fluid, then test drive until reaching 91ÂşC, with the car engine started, it is checked again with the dipstick and it is filled up to position B. Everything was done according to the manual, but my doubt is that after all that process only 6 quarts have been used!. The pity is that we could not verify how much fluid was removed from the car because there was not time to put the bucket, it immediately began to pour liquid on the ground. In all the forums I've seen people tend to use at least 7 quarts or more. What could have happened to only use 6 quarts? Will there be a big problem if in the end a little less fluid has been filled in than what is needed? I would appreciate your opinion, if I can keep calm or have to recheck (it is not comfortable to see that dipstick at high temperature)
