Factory resonator
supercharged680
Dubai
2016 Mustang 5.0 arriving in septemebr
With the laws getting strict in dubai and implementing crazy fines like 27000$ for street racing and 3000$ for driving a modified vehicle, i wouldn't wanna risk it big time lol so i was wondering if the stock resonator is restrictive or not?
i was planning on doing Kooks LT with no cats and a corsa touring axle-back keeping the factory resonator in place.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
On an otherwise stock car, removing the resonator is only worth like 2-4 hp, so its a very minor restriction.
Its got a bigger impact on cutting down on rasp and volume.
PJR202
KY
2016 GT PP Shadow Black
I don't know what the inside of the resonator looks like, but one time on an old car I had, the catalytic converter was clogged up. Since I had to have it to pass yearly inspection I used a screwdriver and broke up all the insides and dumped it out. Then I put it back in place and it never failed inspection.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I'd replace the factory one with the Borla resonator or Magnaflow TruX dual in/out muffler. Less restriction, less weight and better sound with either.
18psi
of boost
Best Coast
I doubt it's worth any power gains, and it is straight through, I've checked. It just necks down inside to 2 relatively small tubes. 2.25 I think (similar to the neck down further up stream)
Lot's of speculation, but I've yet to see anyone show actual gains in a controlled test, even 2-4hp like mentioned above (which would be very hard to actually prove since 2hp is often a variation between runs on the dyno)
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We tested the resonator vs resonator delete several different ways and the delete isn't worth anything for power, only sound and small savings in weight.
Kenbike
Ohio
2015 CO Mustang GT convertible loaded
I running SW long tube headers with cats into stock resonator with Ford Performance touring exhaust. At idel or steady cruising slightly louder then stock, get on it and it has a nice bark!
It is the perfect balance of sound for a old guy.
havasu486
Tinley Park, IL
Ted
2018 Mustang GT350 Electronics Package, Lead Foot Gray
I believe it weighs around 35 lbs.
