Exhaust question
robmustang201528
15 mustang gt302blown
LA
15pp
Water dropping from where my x pipe ends and where my mufflers bolt up to the x pipe. Is that normal or an exhaust leak? Thanks
2 SLOW
Houston, TX
2015 Premium GT
Is this a trick question? If water can get out, air can get out.
robmustang201528
LA
15pp
Will it cause any problems if I don't get it fixed immediately?
mada808
2015 Mustang GT
Probably sounds different depending how much air is escaping but no it won't cause any issues.
Grimace427
NoVA
2011 Mustang 5.0
Some water dripping from between clamps is perfectly normal as long as it isn't excessive. If you also see carbon buildup in the same area that would mean a larger leak that you should get fixed soon. Anything after the cats won't cause any issues at all.
DRKHORS
Mark
'18 F150, '23 Mustang GT
I just started noticing the exact same issue with my cat back system over the past few weeks. Installed the system right at a year ago. I loosened the clamps, made sure they were positioned properly, and torqued to 35 lbs but they are still leaving water spots on the garage floor.
