Engine shutdown before redline
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Tach lag
Rapid Red
Woodstock GA
Greg
Uhhhm, geee... carburetors and lack of EFI?
geee ..................nope,
REV limiter works on both, think again.
WD Pro
United Kingdom
Lime GT
Geared for the track and therefore impossible ? So long as your in the right gear …
Anyhow, Cole Trickle blew his motor purposely in days of thunder … :cwl:
WD :like:
Andy13186
Is this only applicable to the digital dash? The one digital dash car that I did try seemed a bit slower/more laggy than the standard dash with needle. Both the infotainment screen and digital dash seemed laggy to me at that point but the car may have needed a software update or something, this was in 2018.
Anyway on the stock tune my rev limits were different in some gears, like stopped accelerating way earlier in RPM in 5th gear than other gears atleast with the 10r80. With a tune they just move the limiter to 8400 so you almost never hit it, but I have hit it atleast 10-20 times accidently without any problems so far while paddle shifting, it just kills power completely, ive had it even seem like my car turned off a few times but it came back just fine in a couple seconds while still rolling lol
dx2
Germany
Dennis
2020 Mustang GT PP1 Velocity Blue
try to set up the performance shift indicator, makes it easier to notice when to shift, there are a few modes you can use:
Donny53
South Carolina
Don
2021 Mustang GT
Thanks dx2….I’ll try setting that up!!
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
I wonder if this has anything to do with only 1,700 miles? Most definitely the rev limiter. I'd wait till you get to 3 or 4K before you bang it off the rev limiter again, but that's just me.
I generally shift at 7k.
Dave2013M3
El Segundo,Ca
I have a base 300a car with PP, 6MT. My analog tach is a tad behind in 1st. gear as the car revs so fast.
Rapid Red
Woodstock GA
Greg
Rev Limiter is controlled via ignition, interrupting the spark.
MSD offered it as the next gen of the 6A ignition box, don't know the exact origin .
One could almost say there was a mechanical limiter. That being valve float, not predictable, high Rs week springs, range may very.
Points could also float, adding a second return spring the fix.
Of course these are unwarranted, but did limit the RPMs
LOL
With computers and EFI, could assign that duty to the fuel. Howerver that would result in a lean condition and be hard on the motor.
