Engine production question
Elp_jc
None
Hey gang, just saw today a square label with a QR code at the back of the left (driver's side) valve cover on my engine, when checking oil level. It has a date of May 28, 2019, while my car was built in August 09, 2019. Is that the engine build date, or just the valve cover build date? Never seen something like that for any other part, so it might be the engine build date. Just curious if that's the case or not. If it is, surprised how 'old' the engine is compared to the car. Thank you.
JC
Thub
Elgin, Illinois
Jim
2018 GT 6 speed
It's likely the valve cover. A lot of suppliers are moving to serialized parts so they can tie inspection data to a specific part to have some evidence that what they ship is good in case there's an issue later. (I work at an inspection equipment manufacturer)
Elp_jc
None
Makes sense, but then why just ONE such label??? I haven't seen another like that anywhere else, including the other valve cover. Hopefully one of the Ford techs can chime in, and set the record straight :D. Thanks for your input.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
The labels are everywhere, you just didn't look hard enough. Ford actually etched a QR code into the metal parts including the block, water pump housing, etc. If you look with a strong light you can see most of them.
I think the sticker you're talking about is for the engine assembly itself though since it says Essex on it, but who knows. Could just be the valve cover supplier specifying where it goes.
Thub
Elgin, Illinois
Jim
2018 GT 6 speed
The QR codes aren't a requirement, just a helpful 'cover your ass' for the supplier in most cases. Could be that the other valve cover doesn't have one, or it might be in a different location, possibly inside the valve cover. You'll find QR or other 1D or 2D codes all over the car though.
Elp_jc
None
It is indeed the build date of the entire engine.
That's what I thought when I saw it, since I haven't seen a build date of a valve cover prominently displayed before. Thank you for confirming that :).
What doesn't sound right in times of 'just in time' car manufacturing is to build an engine 2+ months before going into the car. Is there a logical explanation for that?
BrianH87
Pittsburgh, PA
2020 Mustang GT ; 2021 Explorer ST
I honestly don't know. But I'm sure there's some time between Essex and Flat Rock. Probably not 2 months, but who knows? Unless they just want a steady inventory of engines to make sure they keep the plant rolling. It's a good question.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Probably has something to do with the Bullitt engine being slightly different, as well as the specific production dates since its a special edition with much fewer builds than normal GT's. My engine is dated October 7th 2019 which is about a week before the car was finished.
Elp_jc
None
That makes perfect sense. But still baffled why 2+ months. Oh well. At least it was past the cam chain tensioner TSB :). Also crossing fingers it doesn't develop the dreaded tick. The infamous 2K rattle is there, but I can live with that.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Mine still doesn't tick, just shy of 5000 miles now and one oil change down already.
Elp_jc
None
NICE. If it doesn't tick by the second oil change, I'd say you're home free with that crap :). I'll find out next week if I pass the 1st oil change test. Ha ha. Have almost 1,100 miles now, so to get the oil hot, it'll be just above that when it gets done.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Hoping it stays tick free! My oil consumption also dropped to almost nil after changing the PCV so thats cool too.
WD Pro
United Kingdom
Lime GT
Just been working on my grill, noticed the date codes and thought of this thread :
Car build date = 26th June
Grill moulding date = Jan 2020
Grill paint date = 21st Jan
Grill production date = 28th Jan (I assume that’s when it got its badge added and QC’d)
WD :like:
