Engine Motor Mounts Recommendations?
Rocketboy
Cinci, Ohio
2015 Roush RS Magnetic Metallic
Only my theory.
When you lower the engine a bind would then be put on the transmission mount and more angle on the output of the transmission shaft. Since, the transmission has a separate mount to support it. It would make the most sense to lower them both together to prevent the drive line from binding. Or to at least to keep it minimal.
Has anyone measured the difference before and after the installation of the mounts?
Lowering the transmission could also help out with the NVH problems as the drive line would be more inline.
zackmd1
Zack
Only my theory.
Driveline angle as measured from the top of the engine is about 3.3 degrees stock. With the maximum drop on BMR mounts without any modifications to the transmission mount the angle dropped to 2.3 degrees.
Rocketboy
Cinci, Ohio
Hi Zack, You have been putting allot of information together for us. I really appreciate all the helpful info.
So it looks like 1 degree change. I remember lowing a truck with lowering blocks. They had a angle cut on 1 side so the drive line angle would decrease at the differential. I was basically using the same theory here. Will pm you for the engine mounts if still available.
Thanks again
zackmd1
Zack
Thanks again
Not a problem! Unfortunately they are no longer available though.
The 1 degree change from my experience had no effect on drivablity or caused and noticeable issues over the time I used them.
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
Just installed GMS engine motor mounts today, DAMN that's a whole lot of NVH!!!
Stupid thing about that mount is, it DOES NOT lower the engine as it claims (0.52 inch)! I only see a 2mm drop judge from the distance from intake manifold to strut tower brace. I still need spacers for clearance.
Now I can only hope the NVH reduces after a break-in period, if there is one. Right now it's a pain at speed below 10mph.
Conclusion is buy BMR ones. At least you get the engine drop as it claims.
zackmd1
Zack
NVH likely will not decrease... I found that out the hard way with the BMR mounts. Best thing I did was make a set of custom bushings with a much softer polyurethane.
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
Bummer... This is too harsh for me.... Where do you get the softer polys that fit the mount? I may go that route as well.
zackmd1
Zack
I ordered some raw material from McMaster Carr and made my own. I went with 40 durometer polyurethane.
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
That's some serious craftsmanship... Thanks for the info!
zackmd1
Zack
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
zackmd1
Zack
Awesome! That's sure helpful!
So going back through my project thread, looks like I used 60A instead of 40A. 40A might end up being to soft to work with. 60A cut out alot of the NVH I experienced but it was not perfect. Low frequency NVH was still present. In gear at idle I could actually see the headlight beam vibrating.
If you have the ability and time, I say experiment with the 40A.
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
Sounds good. I did this in preparation for my pro-charger, as I saw it strongly recommended by a turbo builder.
My procharger kit has been delivered to my Ohio home and waiting for me to carry it to CA (because of the stupid CARB number thing only in CA).
Jared_J
Jared_J
San Diego, CA
2015 Mustang V6
If you guys make some extra sets of said bushings, I'd buy it off you guys.
If I'm going to buy another set of mounts I will start with the steeda ones:
https://www.steeda.com/steeda-adjustable-heavy-duty-s550-mustang-engine-mounts-2015-gt-555-4039.html
Design wise this should truly lower the engine by at least 0.5 inch. The height of GMS ones is about same with steeda ones when with all three spacers on it.
It features two sets of polys, but couldn't find out the stiffness. I will call to ask.It also allows swapping to customized poly bushings.
Steeda says for 5.0 application, but I believe it will also fit V6 since the BMR and GMS ones are universal.
Also update on my current ones: It's more livable today when driving to work. I figured the super harsh initial period may because I disconnected the battery to take off the strut tower brace. The engine needs to relearn to smooth itself. But still, it makes me feel like I'm driving an AMT gearbox. It's fantastic when beyond 3000rpm, but you definitely feel the engine is begging you to speed up when below 2000RPM.
