Engine misfire HELP!!
Jwood1410
Alabama
2016 base gt started showing random cylinder misfires . So I’ve changed plugs once ,changed coils twice .upgraded to gt350 intake manifold with new 47 ib injectors , New throttle body. I’ve reset the ecu following YouTube instructions . Before I changed all this it would throw the code pretty often now it only does it after driving around an hour . I’ve also went to 93 octane with octane booster . It’s seems to run better but I’m at a loss on where to look next any advice would be appreciated
larr12
Alberto
2020 Mustang PP1
Any codes?
Jwood1410
Alabama
P0305 po306
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND, Ford S-Max 2nd series, Lancia Y
These are for cyl 5 and 6.
Did a compressione test? If you worked around the transmission or major engine work, have you done a crank relearn?
SSG 5.0
2017 Mustang GT
Probably yt have crank realarm. It been 3 yrs ago I did mine so I can’t remember how I did it. Also, it might be a stupid question, the plugs are properly gapped?
Jwood1410
Alabama
Ok I’ll try that this evening after work
