Engine internals
OH3Cobra
Indy
2003 Cobra Convertible
my 03 Cobra internals are stout and have held up with 12.5 psi. What do we know about cranks and rods for the 2020 GT500? Did Roush also work on this motor or was. It pure Ford performance?
nastang87xx
San Diego, CA
2016 GT350 Track Pack
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Even the coyote has a forged crankshaft. The Gen 3 coyote also has sintered rods (stronger than cast but weaker than forged). I think I read somewhere the predator internals are forged but can’t recall the source. That said, the article you posted (which I’ve read previously and is very good) says:
“There were a number of significant changes with the crank, connecting rod, piston, block, head, head gaskets, all of the things that you would expect when you are setting up an engine handle 125 bar of firing pressure," Patrick said. "We start with specifying the engine firing pressure and what that pressure curve looks like, and we cascade that out throughout our engineering community. There are a number of a CAE analysis done on the block, crank, bottom-end, bearings, head gaskets and the heads. To make sure everything is capable of handling that kind of pressure.“
