mnmike59
- Apr 5, 2016
- 2 hours South of BIR
- 2016 Mustang GT PP
Good info, Thanks.
Lu47's+Flex fuel log being enabled will get you ready to rock regardless of how inconsistent the the ethanol percentage is.
If you go with a strict e85 tune your fuel trims will correct for some of the inconstancies in percentage but if you run a aggressive spark map it could cause issues...
I usually tune so KR is adding 2*, this give it a safe buffer should you run into lower percentage or warmer summer temps...Also, increasing the KR down ramp will help the ECM pull timing faster should you run into some very low e50-e60 blends. Best thing to do is check with your local car groups and find out who has the most constant mix of e...locally I have about 3 stations that have consistent e85, and 1 that hovers as low as e60 at times.
