E15 gas from race trac
Bill88stang
2016 deep impact blue premium gt 6 speed manual
A new race trac ful station popped up in town, they sell e15 gas has anyone ran it yet?
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
It's basically the same as 87/88 octane... I wish they would have stuck to e85 in all of the new stations.
pmr2000
NC
2016 Mustang GT Fastback, 1975 Corvette Coupe
There are Sheetz stations down here in NC that sell it and it actually is about 5 cents cheaper than 87. Did not try it even in my family car....
wildcatgoal
@sirboom_photography
TBD
E15 is just the gas station being cheap, same as 91 octane. It will just cause, over time, older cars that are not setup for Flex Fuel to degrade faster. It is government-allowed BS, if I'm allowed a stage to proclaim. It will not make your car faster, just burn gas faster.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Why would you want to make less power by running E15?
MikeyV
Bay Area, CA
2014 GT Premium - Brembo - Race Red
Isn't E15 just regular gas? I'm from California, it's all 15% ethanol here.
2015V6Fla
2016 Mustang GT PP Premium MT6
If you can run Ethanol-free fuel, do it. Just run your Ethanol laced fuel down as low as you can before filling up with Ethanol-free. It's not wise to commingle.
Ethanol has a couple bad attributes: 1) it's a solvent and will "clean" the station's tanks/lines and will do the same to your fuel system. And I don't mean "clean" in a good sense. If the station's tank has any gunk in it, Ethanol will clean it there and pass it to whoever is pumping the gas at that time. 2) It absorbs water. While not necessarily an issue in a pressurized fuel system like automobiles, it's a PITA for outdoor power equipment, boats, etc. Absorbing water creates water that doesn't fire in the cylinder and it also causes rust that can clog carburetors or fuel injectors.
Additionally, Ethanol is about a third less efficient than Ethanol-free fuel, so your fuel economy suffers as a result.
My recommendation is to avoid Ethanol if you can. If not, then at least avoid E15, as most fuel systems haven't been adequately tested at that concentration to see if they're able to handle the 50% increase in Ethanol from E10 to E15 (10% concentration to 15% concentration).
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Open your gas cover and look at it - the Mustang is designed for E15. Additionally there are lots and lots of us running e85 with zero issues.
neodark
Left 4cyl @home
Jorge
2019 GT PP2
It's 87+E, not worth it.
Stick to 93 here in FL, we have some of the best pump gas. 91 if you can't find it (CA, etc) or E85 w/ tune on GT, or E30 tune on EB (93+E85 mix to 30% E content). Stock ECU can account for up to E15.
PS: Ethanol has benefits like burning at a lower temp, and higher octane which prevents knock. Our turbo cars love it. And, while not as power efficient as regular gas by volume (read less MPG) the power on E85/E30 is worth it.
Slackaveli
Fayetteville Ar
Ken
2020 Ecoboost High Performance & Handling Packages
put in 2 gallons of e85 with 10 gallons of 93 octane and your ecoboost will run like a scalded dog. My math says that'd be about e17, but, should boost that 93 octane to 94/95 range.
