Dumb tuning/file questions
robvas
MI
2011 GT
Here's some random questions, there's probably a better place to ask them (or maybe where they are already explained), so feel free to point me in the right direction.
If I use an SCT device and use it to download my stock tune file, the resulting file is a little bit over 6 megabytes.
But, if a tuner sends me a file, that I then load on the SCT device, that file is only about 1 megabyte. I assume that it's just patching over my original tune, so it doesn't need to be the full file.
Also, if I use HPTuners to pull my stock tune, the file is only about 1/10th of the size of the 'stock tune file' from the SCT, 563 kilobytes. I am assuming that's because the .hpt files are more of a 'configuration' file and not a full 'tune'? Does that make sense?
I understand that there are things you can get from an aftermarket tuner like a custom operating system, so I realize there's more to a 'tune' than just a bunch of tables. Is there compression involved?
Can anyone shed some light on what's what?
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
My stock file via HPTuners is 1308 kb and my update FRRP tune file is same. Has all info...
engineermike
La
2018 GTPP A10
I'm no expert on this, but my understanding is that all tune files contain all data tables and the C-code logic (the OS). However, each software has different storage formats, which could be .hpt, .bin, .tec, and so on. Each is more or less space-efficient than the others. When you reflash, there are options. For instance, the flash device might just replace the tables, but not the logic, which saves time. Also, PCMTec has a method of comparing by chunk and only flashing chunks that have changed, which gets flash times down under 20 seconds in some cases.
