Driver side water leak?
cprime
Bucks County, PA
Caelan
2020 Ford Shelby GT500
Was vacuuming my car today and noticed the driver side carpet was damp and the underside of the floor mat had condensation built up. Not sure what the issue could be on a brand new 2022 that just hit 1k miles. Anyone else have this problem or know of a possible cause?
Ctodd1
Coral Springs, FL
Scott
2021 Mustang Mach1
Sounds like a/c condensation is possible. Take her right in to check.
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
A friend of mine had the same thing on a new F150, the windshield seal was leaking. Have you been in any rain, car wash, etc..?
cprime
cprime
Bucks County, PA
Caelan
would that require me to have used the A/C? because i don’t think i’ve turned it on once since i’ve had the car. I also just noticed what seems to be hard water stains or soap residue up by the corner where the dashboard meets the a pillar. I saw another thread somewhere about a windshield not being properly sealed and the water was running down behind all the plastic siding and onto the floor
cprime
cprime
Bucks County, PA
Caelan
yeah I wash my car very often and just did today before I noticed the wet carpet. I’m thinking this is exactly my issue
Coastal-Mach
Wilmington, NC
Anthony
Especially on the drivers side, I would take it in, at least its documented.
Pull the door panel and make sure the vapor barrier is sealed at the bottom.
There was another thread elsewhere on here where the vapor barrier was not sealed properly at the bottom and water took the path of least resistance... breached the vapor barrier where the sealant was missing and trickled inside to the floor
Also, check to make sure body seals or plugs are not missing as discussed in this thread, because it's another source of water getting into the cabin:
https://www.mustang6g.com/forums/th...flooded-with-water.101947/page-5#post-2885713
