Does octane booster work
gj
nsw
2017 GT
I've been reading about how gen 2 engines retard timing under certain conditions, mine is a 17 Australian version.
Does it help if you add octane booster while running premium fuel
Car is stock
gj
gj
nsw
2017 GT
Should have mentioned was wondering about using it just at the drag strip
fmc_smt
Cottonwood , Arizona
With crappy fuel in AZ , and being FI , I have to run it . I can notice a huge difference if I don't. 1 Oz To 1 gallon US .
fmc_smt
Sorry , that would be Boostane .
  • Like
Reactions: gj
GregO
Illinois
S550 GTPP
Car is stock
Fuel Octane vs. maximum power/detonation protection required octane is complicated by modern ECU strategies.
To keep the answer to your question simple and all things being equal your motor will run its hardest and fastest ET when using the exact octane required by the designers.
Adding extra octane above the design limit will actually slow the ET and MPH.
Being you’re running a stock program you’ll find the best ET using high quality fresh 91 pump gas octane.
This can become a complicated topic once a person moves into a modified ECU strategy.
ypena02
Massachusetts
2017 Mustang GT
That's not true. Although the benefits of running higher than 93 octane on a factory tune car are probably negligible, it would not slow the car down.
The Demon
Brett
2022 Mach 1 N5809
I have shitty 91 fuel in California. I have a Lund tune. When I run VP fuels OctaniumI can feel a difference to when I’m not running it. I don’t do it often though, maybe once every couple of months just to have a fun tank a gas.
  • Like
Reactions: gj
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Must suck living off 89a .......... :frown: The tourists would drive me nuts. Really takes the fun out of the twisties. :explode: There is a reason I hate pull behind trailers and motorhomes !
cactus_kid
Michael
'21 GT (see sig)
Hell, living anywhere near Dizzy World would cause the car to pull timing. :crackup:
GregO
Illinois
S550 GTPP
ypena02
Massachusetts
2017 Mustang GT
hahaha really? Adding e85 without tuning for it is completely different than running ~95,96 unleaded fuel. Again, on a stock tune the gains would be negligible. However, on a tuned vehicle the higher octane definitely helps. Also, modern ECUs like the one in the s550 mustang account for fuel octane. So the ecu adds timing until it detects knock(up to a certain limit of course). When you run lower octane fuel, the ecu cannot add timing and may actually reduce timing.
GregO
Illinois
S550 GTPP
All good points but my intent was to keep my post directed to the OP who’s running OEM programming. The actual octane # is dependent on the Coyotes designed cylinder pressure / BMEP. Using fuel with an octane higher than this requirement will slow the OP’s car down. This is unless Ford has actually designed the factory program to accommodate a fuel octane higher than pump gas 91/93.
fmc_smt
Early morning runs can be fun , and the damn tourist pay the bills 🙄
gj
gj
nsw
2017 GT
Another thing is our best fuel is 98 RON which apparently is lower than 93 in the USA
GregO
Illinois
S550 GTPP
What is the ethanol % in your Down Under Premium Petro ? Any MTBE added ?
