Does nanny plug disable accelerometer
C-WOODS-70
Illinois
'65 A-Code coupe, '67 A-Code coupe, '22 GT PP 6MT
Was going to do a 1/4 mile run, got thru the choices of "0 to 1/4 mile", "automatic start", but when I "pressed OK to continue" nothing happened. I've got the nanny plug out, so I'm hoping that is the reason.
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
Disconnecting the nanny plug interrupts the data communication to the ABS module, which would explain your issue. Most everything having to do with traction control, stability control, ABS and acceleration will be disabled.
qwiknotch
Southern California
Damon
Kona Blue 2018 Mustang GT,2k GT Vert,
I've made every pass with the plug in. Just hold it until it disables. Works, as long as you don't starting spjnning and slide sideways. But, I've only had one issue with that. Car broke loose at 800ft(ran thru some oil) and the car moved to the right and I guess the rollover failsafe kicked in and it went limp mode. But out of 100+ passes, it only did that once.
