ChromaticGrey
So I've been seeing a lot of talk of the plug that completely disables the traction and stability control. I'd also seen talk of it on youtube etc.
I decided to try it out to see if i noticed a difference compared to just using the button to disabling traction control or advancetrac. Ya know, science. I didn't notice a difference, from a stop, from a roll, or highways speeds as far as response or speed. The ole butt dyno didn't notice anything, who knows if I'm right.
The one thing that did happen. The very first startup after unplugging the harness behind the air box. Upon startup I had a message that said "Steering Assist Fault Service Required". Of course the advanctrac and traction lights were lit up. Figured it was a weird way of the car saying you don't have any help if things go bad. I didn't worry about it as I've heard people drive with this unplugged, but never heard this part, and of course was not going to be an idiot.
Nothing was wrong. Steering mode was still selectable(i don't have drive modes, just steering normal, sport, and comfort) I've been driving it this way a couple days, this may have been the 3rd morning. I am backing out of my driveway this morning, and as i come to the end and go to turn, i don't have power steering, i also didn't have the steering mode selectable, it was stuck on normal. It had been fine for a couple days with the warning, but functioning correctly otherwise. So i pull over in the neighborhood, shut down the car. I plugged the nanny plug back in. Started up, and it was still seeing the fault. Turned the car off again at the next light gave it about 10 sec, turned it back on, same thing. So i just drove to work without power steering, no big deal, figured it would fix itself while driving. It did not. Sat for around 4 hours at work and when i started it up, it was fine, no warning, steering working again. Probably didn't need 4 hours, but more that a minute or so it may have been required
IDK, I just wouldn't recommend that you unplug it. Obviously i don't think any harm was done. Not like power steering is 100% necessary, but it sure didn't feel as good without it. But no need to deal with that, especially if it would have happened mid turn or something.
I have read of the steering fault just happening randomly(after looking today), but doubt it was random as it was directly correlated with the unplugging. Then being plugged back in.
Anybody else have this issue, from what I've seen nobody mentioned this happening to them when unplugging the connector. Aren't one or two of you running it unplugged all of the time?
EDIT: Found this online. My wrench was not lit up, but advancetrac and traction lights were.
