ChiTownStang26
Just got my base tune from lund and going to try to flash it today but ive seen before that its recommended to use a trickle charger for the battery so it doesn't die midway through flashing. Considering I have a premium with the sub-woofer and all those fancy interior lights will it be a problem if I just flash on the battery alone? Could I just turn off the radio while I flash? If not could I run jumper cables from my girls car so I dont have to buy a battery booster?
Side not im also installing the 47lb injectors prior to flashing and im guessing I should disconnect the battery first, install injectors, reconnect battery, flash, then crank the car?
I'm a little nervous about hearing you can grenade the computer if it dies mid flash but dont want to spend $100 on a battery booster for a one time use if its not necessary, so anyone that could give me a little clarity for this would be greatly appreciated. Thanks!
