Even though I'm not planing on any further mods. I am quietly following this thread. Totally admire your attention to detail and reporting. Can't wait to see the final result. Keep it up. cheersOh, and it seems that the top seal wouldn’t be able to bridge the gap to the hood liner either.....
Note how I’ve greased up some cable-tie off cuts, stuck them to the shield, closed the bonnet and then worked out the gap based on that.
I couldn’t think of an easier way to do it. If you have one, please share.
The fix will be as simple as lining the inside of the shield with some adhesive neoprene to prevent heat transfer into the compartment and probably some plumbers lagging (the black stuff) rolled over the top edge of the shield to make it seal to the bonnet properly. I’ll be leaving it open on the inner guard side simply because it’s a good potential source of clean air.
Whether this matters or not or even if it’s going to work, I can’t say for sure.
I’ll be sharing the pics of the final result once it’s done. :cheers:
Mr. Fiz...So Burkey,
How goes this epic bit of DIY my friend?
All power to you for attempting. Has it hit a bit of a snag or are you just needing a break from it for a while?
All the best with it.
Cheers mateThats pretty cool. I too was disappointed with the airbox Whipple supplied. I am going to play around with sealing it a little better. One thing to consider if you haven't already is to open up the grill a bit. Made a big difference with my Steeda CAI.
I now took all the hexes out and put a Velossa big mouth in its place, so there is a nice direct route for cool air to get into the box.
:cheers: I was wondering how you did that!Cheers mate
VTBM is already fitted and the honeycomb completely removed from that side. I did that around the time I fitted the PMAS intake. The opening is actually quite handy for passing the leads through when doing the backlighting stuff
