DIY A/C Compressor Clutch and Coil Replacement
sonicc
Mr. Bond
St. Louis
2015 Mustang GT
I take no responsibility if you mess up something or get injured. These instructions are provided as a reference to help out with this job.
A few days ago the A/C stopped working on my 5.0 and it started making a grinding noise whenever I'd try to turn on A/C. Took a look under the hood and this is what I see sitting on top of the sway bar:
The hub/compressor pulley (part with clutch material) was all chewed up
This is at 50k miles, so out of warranty. The bolt that holds it was nowhere to be found...good thing it wasn't caught by the accessory belt.
I tried to find a DIY on how to do the A/C compressor clutch, but without much luck, so I bit the bullet and got a 3 day subscription to Ford/Motorcraft service manual to tackle this. This write up is for 5.0 but clutch replacement will be similar for other engines too.
I ordered the OEM Motorcraft A/C clutch that comes as a kit with clutch plate, hub, and coil from RockAuto. It's about $100 cheaper than ordering from Ford (at the time of writing this).
Tools:
  • 10mm socket
  • feeler gauge
  • torque wrench (one that measures in in-lb preferably)
  • zip ties
  • small pry bar
  • 18mm socket, ratchet, and breaker bar
  • gear puller
  • snap ring pliers
Step 1:
Start by removing the intake tube and overflow bottle. Remove upper radiator hose for better access (drain radiator first or coolant will be drained for you via other means all over your garage floor).
You'll be looking at something like this:
Step 2:
Since my clutch plate fell off, I didn't have to deal with removing that. If yours is still there, you'll need to remove the 10mm bolt that's holding it.
You'll need something to hold the plate in place while you take out the 10mm bolt.
Step 3:
Now you need to remove the belt for A/C compressor. The 5.0 engine uses a separate belt for A/C and there's no tensioner or way to adjust/loosen the tension. Factory service manual calls for cutting the A/C belt in order to remove it . I wasn't going to do that.
Put an 18mm socket on the crank bolt, put the ratchet, and use breaker bar to turn the engine clockwise. Use a small pry bar to get the belt to slip off the compressor pulley. Once it's off the compressor pulley, move the belt out of the way.
Step 4:
In order to be able to remove the compressor pulley, there's a snap ring that needs to be removed. I forgot to take a picture, but it is illustrated here:
IT IS VERY IMPORTANT TO GET A GOOD PAIR OF SNAP RING PLIERS for removal and re-installation of this snap ring. You'll hate life if you don't. The ones at part stores suck.
Step 5:
Now put the gear puller around the pulley and remove the pulley. You can probably use pry bars, but I wouldn't recommend it.
After you remove the compressor pulley, you'll be looking at the clutch coil
I decided to replace mine since it came with the kit and it would suck having to do this again in case the coil fails down the road. The coil is held in place by 3 screws. Remove them, slide the coil off, and unclip and disconnect the power connector behind it. Install new coil.
Step 6:
install the new pulley/clutch hub. Process is the opposite of Step 5, without the use of gear puller obviously. I used a small hammer to tap around it so it goes evenly until it was fully seated on.
Step 7:
With hub (compressor pulley) seated on, use the snap ring pliers and install the new (or old) snap ring.
Step 8:
Now's the fun part of putting the belt back on. At this point it might be easier to remove the accessory belt - which is how service manual describes it.
Take the A/C belt and twist the belt so the ribs face the front of the car (as illustrated in the image above), then slip it behind the crankshaft pulley. Once it's completely behind the crankshaft pulley, slide it on the compressor pulley and make sure it's fully seated in the groves on compressor pulley.
Now get the belt started on the crankshaft pulley (closest to the compressor). At the point where belt can't go on any more, take a zip tie and feed it through the spoke of the crankshaft pulley and then over the belt. Picture below shows how it's done with accessory belt out of the way. The idea is the same - to have the zip tie hold the belt in place while you rotate the crankshaft. If the accessory belt is still in place then the zip tie has to be installed a little before the spot illustrated in pic below:
With zip tie holding the belt, start slowly rotating the crank with ratchet and breaker bar. If you opted to not remove the accessory belt previously, the zip tie will eventually get stuck on it as you turn the crank. Cut the zip tie as the belt should be on far enough at this point to not slip off the crankshaft pulley. If it does slip off, you'll need to repeat this step.
With zip tie cut off, start rotating the crank slowly and make sure the belt is going on. As you make a full rotation the belt should seat onto the crank fully, just make sure all the ribs are in the grooves. If one of the ribs is off, you can use a pry bar to push/guide it into the right spot as you rotate the crank.
Rotate the crank a few times just to make sure the belt is on there correctly.
Step 9:
Now's time to install the clutch plate. If you ordered a kit, it should come with some washers/spacers and a new bolt. Those washers are needed to set the correct gap between the plate and hub. Put all the washers into clutch plate spline part that goes onto the compressor shaft, put the clutch plate onto the shaft, and then install the 10mm bolt. Tighten the bolt just tight enough for now, it will get torqued later.
You will need a feeler gauge to check the gap between the clutch plate and the hub (compressor pulley). If you're not sure which one is which at this point: the black part is the clutch plate and the part where the belt goes on is the hub. Feeler gauge needs to slip between those two. Per the factory service manual the gap should be between 0.3mm and 0.6mm. Check the gap at 3 points that are about equal distance from each other - I used the silver rivet looking things as reference.
If the gap is outside of those specs, you'll need to remove/add spacers.
Once the gap is set, you can now torque the 10mm bolt to 177 in-lb (~15 ft-lb). Pay attention to which units your torque wrench has or you'll have a bad day.
Step 10:
Reinstall everything removed in step 1, add coolant, etc.
Test out the compressor by turning on A/C
Hope this was helpful.
speedup
DFW
2019 triple black GT convertible
Great write up and pics! thanks!
Densefuck
South Texas
2016 mustang gt
Yo i an trying to replace the coil clutch and pulley for the ac but the new kit i got is different from the damaged parts. The new assembly is bigger and is getting stopped by the sway bar where as the bad one has a smaller coil that doesn't need the 3 screws to hold it up.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Looks just like the Taurus ones I used to do back in the day, clearly Ford still hasn't learned how to make a compressor clutch last. Two things I'd recommend to add, one is that instead of using a pry bar to remove the old belt, you can just use any old rag. Secondly, blue loctite on the hub bolt. Knock off 2ft/lbs on the spec and it should hold no matter what.
Definitely a good tech thread that should be pinned with the other A/C related issues - since it seems the S550 A/C system has quite a few faults (for the early 2015-17’s).
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
Does anyone have any tips on getting the new pulley back on the compressor? There isn't a lot of room to swing a hammer down there and it doesn't slide back on (however it is halfway on now). The old one was a bitch to take off with the puller
Autozone has tool rentals, but I am not sure if any of those would help force a pulley back on, has anyone else done this on a mustang? I will try swinging a smaller hammer or wrench soon.
I wish I would have just replaced the clutch plate and left the old pulley haha
Here ya go, see if any of the tech/images in these (2) threads offers any additional assistance.
This thread has the info from the Ford shop manual for how to remove the clutch assembly/field coil:
https://www.mustang6g.com/forums/th...tentially-a-c-compressor.129712/#post-2686995
There is also this thread which discusses how to remove the A/C stretch belt (and an available Lisle tool to do it too):
https://www.mustang6g.com/forums/threads/ac-stretch-belt-help-please.175709/#post-3554880
illadvised
San Diego
Brian Spilner
Thanks for that. Unfortunately not much help on reinstalling the pulley, just the removal. Most guides simply state reverse the steps to reinstall, which leads me to believe that mine is an abnormal situation.
I am still going to try the hammer method and see if that works. I might need an entire new compressor if something with it isn't letting me slide the pulley on with ease
natepcbfl
New Hope, AL
Nathan
2015 Mustang Premium GTpp 50th AP ---- 1989 Mustang GT 25th Anniversary
Thank you so much for the thread. Just an FYI to anybody else, you might want to have a blind hole bearing puller in case you run into what I did, which was the pully came off but the bearing stayed stuck on the shaft. Side note: I was also able to not open the cooling system (just bungeed the overflow and hoses back) and pulled the radiator fan for more room.
