Display configuration
dclement
France
Daniel
2019 Mustang Bullitt
Hi all,
There's 2 adjustments I'd like to make on my display (not sure it's possible):
1) the center display: I usually leave it on gauges (quite nice looking) but at times I'd like to switch quickly to tire pressure. I don't know how to do that without delving into the menus, and afterwards I need to reconfigure the gauges. Please prove me wrong!
2) the GPS: after I set up a destination, I'd rather see the ETA instead of the remaining time. I thought it would be enough to click on the latter display, but it doesn't work as I expected. How could I do that?
TIA - best regards, Daniel
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The tire pressure is only found under vehicle options, which is a separate key from the MyMode options. There's no way around that. The quickest way to see tire pressure is to leave it on that page when you go back to MyMode.
dclement
France
Daniel
Ah, thanks, I see, I was not aware that MyMode (which I didn't use) included the choice of display. So all I have to do is put the tire pressure on screen and save MyMode, is that correct?
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The MyMode section is where you configure the gauges. The tire pressure is in a separate options file. You can’t marry the two together.
Ixxion
Tom
2020 Mustang GT Convertible
Do you have access to the FordPass app? Maybe you could work something out there…
dclement
France
Daniel
Thank you for your Evolvd and Exxon for your last answers.
It's a pity one can't get the tire pressure simply by cycling through the displays with the up/down keys.
On the Explorer, that's how it works, one just has to select what to include in the cycle. It's much easier, and I expected something like that on the Mustang.
Of course there's the FordPass app which can show the pressures. It might be simpler to open it than to go into the menus on the car!
PoCoBob
Port Coquitlam B.C.
Bob
2019 Mustang GT Premium, 2016 Edge Sport
You have a Bullitt and I have a GT so mine may be different. But to see the tire pressure I hit the settings button on the steering (looks like a little gear) and choose the trip menu. Then I scroll through the windows using the up/down arrows and the tire pressure is in there. To get back to the gauge screen I press the pony button on the steering wheel (looks like a horse) and the option for gauges shows up, I think it's the third one down so I move down with the arrows and hit the ok button.
My car is parked for the winter so I'm going by memory here but I think I've got this close enough to figure it out.
The Spider House
Lancashire
Phil
Ford Mustang Mach 1
It is! Ha ha
The only thing the app warns against is delays in readings so may not be real time.
I use the app (plus a gauge if im doubt) as its too much of a faff on the cluster.
I have 3 gauges on display on mine although I think there is an option to display a list (incl tyre pressure????)
Edit...posted at same time as PoCoBob who I think has just described what I was referring to?
