willmkent
'Twas sure good see'in ya
Why would the bypass valve open when the car is in vacuum? Shouldn't it only open with a build up of pressure when the throttle body is closed? I mean I know this thing isn't an HKS SSQVII or anything but, the purpose is the same...I'm not quite sure if there are no ill effects. I too experienced opening of the factory bypass valve under partial throttle conditions. In these cases, the engine was operating under vacuum. Since I had the Boomba adapter installed at the time (essentially the same as disconnecting the recirculation hose), unfiltered air was entering the engine during these periods. I elected to remove the adapter and run the stock recirculation setup, instead choosing to install a JLT intake to improve sound among other things.
Will the small amounts of unfiltered air entering the engine through the vented-to-atmosphere bypass valve during these conditions cause engine damage? Possibly in the long term, but by then, there's no way to tell that the bypass valve being vented is what caused any problems that may develop. I weighed the risks vs. rewards, and did what suited me best. Others may think and choose differently.![]()
