Digital speedometer stops at 160
zero_chance
Dismember
Arizona
JD
2017 GT Premium w/ Performance Pack
FruityJudy
South Alabama
2018 Mustang GT A10
You can have the digital cluster re-programmed to be a bullet cluster with the 180mph limiter, or hellhorse now offers the GT500 digital cluster with 220.
Tuners can remove the speed limitation up to 186mph. If you unplug the ABS bypass plug in the engine bay, it removes the hardcoated 186mph limit as well. Mine is on a switch using the 580P&P bypass mod. I hard disable all the nannies for the drag strip or when doing dumb stuff. lol
So what about your driving modes? It disables them also when activated corrrect?
Elp_jc
None
Regular GTs are speed limited to 155, which with the typical error, would be 160 indicated. Unless you have a tune, that's the reason for that :D. Bullitts are limited to 163, by the way, to make us feel 'special'. Ha ha.
CORNYOTE
Oklahoma
Alex
2019 GT
No, it appears it stays in whatever mode you’re in at the time when the button is pressed. You cannot change modes while it’s disabled though.
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Well, that will certainly do it. Another poster confirmed with standard power that 181 at least is possible on a slight uphill.
He said he had an E85 tune and long tube headers. That's a decent amount more power than stock, so a stock 2018+ may not be able to hit 181 mph on stock power. I would bet a bone stock car could do 170+ mph though.
